Page 1 of 2
audio recording support
Posted: Sun Oct 23, 2011 4:43 pm
by scooter35
I would like to be able to record audio from my foscam when an event is triggered, and then stop recording at the end of the event.
Re: audio recording support
Posted: Wed Nov 23, 2011 6:57 am
by gmar_87
+1
Posted: Fri Feb 03, 2012 9:25 pm
by Harbinger
++1.
This feature has been discussed/requested before, but the response(s) seem to indicate that it's somehow not a simple task. It HAS to be doable; BlueCherry sells a program that's Linux based that works with their hardware-compression card and it supports audio.
Posted: Fri May 25, 2012 7:04 pm
by RootAdmin
+1
It may be possible to begin to play the events stored in the folder file (s) of sound. And to carry out an external recording the script,passing it as parameter the source address and the path to the event.
Posted: Mon Aug 27, 2012 1:26 am
by dcabot
+1
Posted: Fri Feb 08, 2013 11:28 pm
by Azelphur
+1, my camera outputs audio on the RTSP stream, it should be easy to capture (VLC handles it no problem)
Posted: Sun Feb 17, 2013 12:14 pm
by grantusmaximus
+1
Posted: Sat Mar 02, 2013 10:16 pm
by jameswilson
my 2p.
Being from the UK recording audio is fraught with danger. While thats no reason not to do it in a domestic environment its not best to do in any other environment.
Problem is time for phil. We have added many features to zm over the years with some funding support from ourselves. This is continuing but I personally have no need for audio recording.
I believe the next version of zm is a huge rewrite and will be a big version jump. But its still early days in its development cycle.
Posted: Thu Mar 07, 2013 2:49 am
by dcabot
audio support +1
Posted: Fri Mar 29, 2013 9:06 am
by Moleij
Audio support would be great
I donated a small amount now, will donate again if ZM record sound - see it as a carrot
I just installed ZM for the first time to a small portable system, actually running off a USB stick based on Mageia2 liveCD, and handle one USB camera.
Posted: Fri Oct 18, 2013 12:27 am
by iconnor
Who did you donate to? On here? That goes to the original developer, who is no longer active. Doesn't go to anyone actually working on the code.
For donations, please contact the developers at github, or use bountysource.com
Posted: Tue Dec 08, 2015 7:27 am
by shinji2009
also +1, both hands
Posted: Wed Dec 23, 2015 9:45 pm
by junior
That would be a very nice feature!!
Posted: Thu Dec 24, 2015 8:41 am
by Nerre
I guess the major problem with audio recording is that ZM in its current state does not record video streams. While ZM may read video streams, it still analyzes and records them as JPEG images. This means it will be very hard to synchronize any recorded audio with the playback of those stills.
If/when ZM is rewritten to record video, recording audio will most likely come "at the same price".
Posted: Sun Jan 10, 2016 5:20 am
by shinji2009
it will be ok if zm record video separetely in separete file with same name as videofile, because nowdays most videoplayers able to automatically attach audio to video during playback. and file length could be +-1s sync is not so important
