Sudden pixelation
momcilosystem
Sudden pixelation
Post by momcilosystem »
Hi guys, I just installed Zoneminder on Fedora 14 box and it works very good.
I do have one problem. My monitors randomly pixelate and then just correct themselves after few minutes. It's not one camera that have this problem, it's both of them randomly and it triggers my modect.
I attached frame before pixelation and next one in which pixelation occurred. I also attached comparison image.
My kernel values are:
shmall = 4073421778
shmmax = 4073421778
I got this values by trial and error method :) I kept increasing value until both cameras worked at 704x576
Any help would be appreciated.
Comparison
Comparison
Frame in which pixelation occurred
Frame before pixelation
mastertheknife
Re: Sudden pixelation
Post by mastertheknife »
What cameras are you using?
mastertheknife
Kfir Itzhak.
momcilosystem
I am using two analog CCTV cams on GeoVision 250 card.
I don't think that cameras names are a known brand so I attached pictures of cam.
Thanks for your reply.
Front side
Front side
Back side
Back side
TucsonDirect
Post by TucsonDirect »
this is an interlacing problem
And it is most likely your capture card, there is nothing you can really do, IF your camera has a line lock (LL) setting try changing the settings to internal (INTL) or Line Lock (LL) i think this usually happens when the voltage changes on your power supply line, like when an A.C. unit starts up... (When using cameras that are AC)
TucsonDirect
just a side note you might want to get a camera that has back light compensation (BLC) for the location of your posted images
ETA:
Change these setttings on back of camera
AWB- ON
AGC- ON
EE>OVER TO AF(play with this one...
BLC ON
ground loops can also play a part in the problem if you are powering the camera from a cheap power supply
