Page 1 of 1
Unable to view event & create s.sock files
Posted: Wed Oct 26, 2011 9:25 pm
by fri.K
Hi, for some time (maybe since -3500?) I can't view events.
When I start to play event (middle network usage), I see black window with text
Time to next event = 1 seconds
Then in debug log I get
zm_debug.log.10604:10/26/11 22:52:53.876232 web_php[10604].ERR [socket_sendto( /tmp/zm/zms-712705s.sock ) failed: No such file or directory] at includes/functions.php line 2322
But in same time
ll /tmp/zm
razem 3756
drwxrwxrwx  2 www-data www-data    4096 2011-10-26 22:52 ./
drwxrwxrwt 62 root     root       20480 2011-10-26 22:52 ../
-rw-r--r--  1 www-data www-data       0 2011-10-26 22:50 zmaudit.log
-rw-r--r--  1 www-data www-data    1032 2011-10-26 22:50 zmdc.log
srwxr-xr-x  1 www-data www-data       0 2011-10-26 22:50 zmdc.sock=
-rw-r--r--  1 www-data www-data      67 2011-10-26 22:50 zmfilter.log
-rw-r--r--  1 www-data www-data      59 2011-10-26 22:50 zmpkg.log
srwxr-xr-x  1 www-data www-data       0 2011-10-26 22:52 zms-712705w.sock=    <---
When I switch to high net usage i see first image of event but it doesn't run. There is no "socet_sendto" error in log but:
# ll -h /tmp/zm
razem 14M
drwxrwxrwx  2 www-data www-data 4,0K 2011-10-26 23:01 ./
drwxrwxrwt 62 root     root      20K 2011-10-26 23:00 ../
-rw-r--r--  1 www-data www-data 1,1K 2011-10-26 22:50 zmdc.log
srwxr-xr-x  1 www-data www-data    0 2011-10-26 22:58 zms-027347s.sock=
srwxr-xr-x  1 www-data www-data    0 2011-10-26 23:01 zms-704233w.sock=
srwxr-xr-x  1 www-data www-data    0 2011-10-26 22:57 zms-878201s.sock=
After while sock= files are auto removed.
OS: Ubuntu 11.04 x86_64
kernel: 2.6.38
ZM: 1.25.0-3500
Two cams: 1x bttv, 1x http
Recording and motion detection is working ok, streaming in high and middle is also ok, making video of event is ok.
So is there bug with names mismatch: w != s and last character "="?
Edit 1
I read code a bit. Now I know that it spose to be two sock files w.sock and s.sock. Before s.sock file appears for a second and die, now it doesn't appear at all.
I renamed my 1.25 database and made default one. Now I'm unable to see stream either. I modified code to see more in debug log. Fist I modified ajax/stream.php - there is no much to see - it able to access w.sock file, gets some connkey and unable find s.sock file.
Then I modified src/zm_stream.cpp
void StreamBase::openComms()
    if ( connkey > 0 )
        sd = socket( AF_UNIX, SOCK_DGRAM, 0 );
        if ( sd < 0 )
            Fatal( "Can't create socket: %s", strerror(errno) );
            Debug(3, "openComms() Cant create sd ");
        snprintf( loc_sock_path, sizeof(loc_sock_path), "%s/zms-%06ds.sock", config.path_socks, connkey );
        Debug(3, "openComms() Unlinking loc_sock_path: %s ", loc_sock_path);
        unlink( loc_sock_path );
        strncpy( loc_addr.sun_path, loc_sock_path, sizeof(loc_addr.sun_path) );
        loc_addr.sun_family = AF_UNIX;
        if ( bind( sd, (struct sockaddr *)&loc_addr, strlen(loc_addr.sun_path)+sizeof(loc_addr.sun_family)) < 0 )
            Fatal( "Can't bind socket: %s", strerror(errno) );
        snprintf( rem_sock_path, sizeof(rem_sock_path), "%s/zms-%06dw.sock", config.path_socks, connkey );
        strncpy( rem_addr.sun_path, rem_sock_path, sizeof(rem_addr.sun_path) );
        rem_addr.sun_family = AF_UNIX;
void StreamBase::closeComms()
	Debug(3, "closeComms() Attempting to close sockets");
    if ( connkey > 0 )
        if ( sd >= 0 )
        		Debug(3, "closeComms() Closing sd ");
            close( sd );
            sd = -1;
        if ( loc_sock_path[0] )
        		Debug(3, "closeComms() Unlinking loc_sock_path: %s ", loc_sock_path);
compiled and repleced in proper path but there is no any "closeComms" word in logs, why?
Edit 2
I switched to 1.24.2-8 (Ubuntu package), now I able to see live jpeg stream but no mpeg stream in browser - mpeg plays well in Totem.
There is steel "socket_sendto( /tmp/zm/zms-399721s.sock ) failed: Connection refused, " issue, but this time s.sock files are created and newer destroyed:
ll
razem 56
drwxr-xr-x  5 www-data www-data  4096 2011-11-01 10:24 ./
drwxrwxrwt 41 root     root     20480 2011-11-01 11:05 ../
drwxr-xr-x  2 www-data www-data  4096 2011-11-01 09:27 log/
-rw-r--r--  1 www-data www-data     0 2011-11-01 09:40 zmaudit.log
-rw-r--r--  1 www-data www-data  1557 2011-11-01 09:40 zmdc.log
srwxr-xr-x  1 www-data www-data     0 2011-11-01 09:40 zmdc.sock=
-rw-r--r--  1 www-data www-data   198 2011-11-01 09:40 zmfilter.log
-rw-r--r--  1 www-data www-data    58 2011-11-01 09:40 zmpkg.log
srwxr-xr-x  1 www-data www-data     0 2011-11-01 10:21 zms-177825s.sock=
srwxr-xr-x  1 www-data www-data     0 2011-11-01 09:57 zms-235785s.sock=
srwxr-xr-x  1 www-data www-data     0 2011-11-01 10:16 zms-399721s.sock=
srwxr-xr-x  1 www-data www-data     0 2011-11-01 09:50 zms-413119s.sock=
srwxr-xr-x  1 www-data www-data     0 2011-11-01 10:14 zms-497295s.sock=
srwxr-xr-x  1 www-data www-data     0 2011-11-01 10:21 zms-624466s.sock=
srwxr-xr-x  1 www-data www-data     0 2011-11-01 10:04 zms-965676s.sock=
drwxr-xr-x  8 www-data www-data  4096 2011-11-01 10:23 zmswap-m1/
drwxr-xr-x  3 www-data www-data  4096 2011-11-01 10:22 zmswap-m3/
-rw-r--r--  1 www-data www-data   420 2011-11-01 09:40 zmwatch.log
So it seems to be operating system/http server related?
Re: Unable to view event & create s.sock files
Posted: Mon Nov 21, 2011 5:09 pm
by Jason_Bassett
Seems similar to my issue, did you get this sorted out 1.25.0?
My Apache logs show the following when I try to view a monitor:
[Sat Nov 19 19:57:32 2011] [error] [client 172.16.1.210] ERR [socket_sendto( /tmp/zm/zms-862166s.sock ) failed: No such file or directory], referer: http://myhomepc/index.php?view=watch&mid=2
The /tmp/zm folder exists with just 1 file in it (zmdc.sock) and the /tmp/zm/zms-862166s.sock file is created and destroyed every five seconds or so.
Images are being recorded and stored and I can see the preview image when I go into the zone configuration area.
Jason
Posted: Sun Apr 08, 2012 1:06 am
by Classic
Hi, can you resolv it? i have the same problem, but only when i want stream mpeg (swf)...
Posted: Sun Apr 08, 2012 11:29 am
by Jason_Bassett
Not yet, I have abandoned by Zoneminder box at the moment in favor of tinkering with MythTV and Airtime. When I get it going I will post my findings though.
J
Posted: Sun Apr 08, 2012 6:13 pm
by _saiko
Same problem here regarding the ERR socket_sendto in my logs.
Posted: Sat Apr 28, 2012 5:42 pm
by timmans
Has anybody got a answer to this problem?
I am running Ubuntu Server 12.04 with Zoneminder 1.25 installed from the software centre. I have so far reinstalled it twice and have got the same problem:
2012-04-28 13:08:01.708001 web_php 19296 ERR socket_sendto( /tmp/zm/zms-988694s.sock ) failed: No such file or directory /usr/share/zoneminder/includes/functions.php 2322
2012-04-28 13:07:55.684833 web_php 19296 ERR socket_sendto( /tmp/zm/zms-988694s.sock ) failed: No such file or directory /usr/share/zoneminder/includes/functions.php 2322
Interestingly I have installed Zoneminder on Ubuntu Desktop 12.04 and it works fine.
Posted: Tue May 01, 2012 1:45 am
by Classic
really? you don`t change anything...only the dist? it`s so rare...please check an tellus if you see some diference can explain that...(sorry for my english...)
Posted: Wed May 02, 2012 3:06 am
by Classic
after try many times with different configuration, i think this error it`s about shared memory, because when i set mpeg(swf) low resolution and 1/2 scale work well,more than this, not work, maybe the ffmpeg encoder need more memory for create swf live stream, because with asf work ok, but have buffering and swf not.
In other post I read the solution it`s configure zoneminder with mmap enable, but i test it on ubuntu server 11.10 64 bits version 1.25.0 with quad core 9550 and 8g ram (1600 mhz bus) with only one cam axis 207 in 640x480 and not work!
well, i`m keep trying, any news i post here..
Posted: Fri May 04, 2012 12:07 pm
by piglet_74
I'm also getting a similar error. I have had a few installations of zoneminder over the years. This time I was building a system using the 12.04 Beta version of ubuntu. It worked well for a few weeks. I made the mistake of messing with ffmpeg and apt-get uninstalled my zm install. I tried re-installing and started having problems with all sorts of stuff. So I downloaded the latest 12.04 and tried a clean install. I started noticing the error every 5 seconds or so and the w.sock file being created in the /tmp/zm/ folder. When I try to watch live video I get unable to authenticate user in the log file.
I tried upgrading php to 5.4 dev but that made the main page completely useless. I tried re-installing from the beta cd I made but the problems are still there. I'm wondering when php 5.3.10 was released and if that's the issue. I've tried to install 5.3.9 but don't know how to make zm use that instead of 5.4 since apt-get puts that on the machine when I install zoneminder. I also tried to build zm from source but failed make with errors about zm_local_camera or something and didn't have the time to chase it down.
If anyone has any ideas on how to get 5.3.9 running with zm 1.25 I'd like to give it a try just don't know how.
Thanks, Rob.
Posted: Sat Jun 30, 2012 6:24 pm
by cbagwell
piglet_74 wrote:I'm also getting a similar error. I have had a few installations of zoneminder over the years. This time I was building a system using the 12.04 Beta version of ubuntu. It worked well for a few weeks. I made the mistake of messing with ffmpeg and apt-get uninstalled my zm install. I tried re-installing and started having problems with all sorts of stuff. So I downloaded the latest 12.04 and tried a clean install. I started noticing the error every 5 seconds or so and the w.sock file being created in the /tmp/zm/ folder. When I try to watch live video I get unable to authenticate user in the log file.
I was having similar issues and the solution turned out more related to the "unable to authenticate" message then it was to the socket. The socket message just shows up more in the log file.
Based on hints in other threads, I traced issue down to at least AUTH_RELAY setting in options. If you set to "plain" or "none" then it started working.
I reviewed zm_user.cpp, were authentication is occuring when in default "hash" mode. I noticed among other items, its including the current hour in hash string. Finally, I tracked down PHP to default to UTC timezone and so its hash was based on wildly different hours.
The fix for me was to edit /etc/php.ini, uncomment the date.timezone line and and; in my case; change the line 'date.timezone = America/Chicago'.
Now the hash is built with matching hour+date.
Chris
Posted: Wed Jul 04, 2012 2:23 pm
by piglet_74
Thanks for the reply. I'm looking forward to backing up my 1.24 install now and trying 1/25 again. Thanks, Rob.
