I'm trying to configure a Flir F-Series thermal camera with zoneminder but I can't get it to work.
ZM can't process the stream, I tried with MJPEG, MPEG4 and H.264 but all give me errors.
The problem I get using MJPEG is:
11/05/11 15:49:17.473115 zmc_m1[2445].DB2-zm_rtsp.cpp/477 [Got RTP Info url=rtsp://10.0.2.189/ch0/track1;seq=50814;rtptime=3733474012]
11/05/11 15:49:17.473145 zmc_m1[2445].DB2-zm_rtsp.cpp/496 [RTSP Seq is 50814]
11/05/11 15:49:17.473153 zmc_m1[2445].DB2-zm_rtsp.cpp/497 [RTSP Rtptime is 3733474012]
11/05/11 15:49:17.473184 zmc_m1[2445].DB3-zm_rtp_source.cpp/43 [RTP CName = zm-1@zm]
11/05/11 15:49:17.473195 zmc_m1[2445].DB3-zm_rtp_source.cpp/68 [Initialising sequence]
11/05/11 15:49:17.473206 zmc_m1[2445].DB1-zm_thread.cpp/241 [Creating thread]
11/05/11 15:49:17.473213 zmc_m1[2445].DB1-zm_thread.cpp/241 [Creating thread]
11/05/11 15:49:17.570917 zmc_m1[2445].DB4-zm_rtsp.cpp/573 [Read 4 bytes on sd 4, 4 total]
11/05/11 15:49:17.570937 zmc_m1[2445].DB4-zm_rtsp.cpp/582 [Got 4 bytes left, expecting 1024 byte packet on channel 0]
11/05/11 15:49:17.570946 zmc_m1[2445].DB4-zm_rtsp.cpp/585 [Missing 1024 bytes, rereading]
11/05/11 15:49:17.571347 zmc_m1[2445].DB4-zm_rtsp.cpp/573 [Read 1024 bytes on sd 4, 1028 total]
11/05/11 15:49:17.571368 zmc_m1[2445].DB4-zm_rtsp.cpp/582 [Got 1028 bytes left, expecting 1024 byte packet on channel 0]
11/05/11 15:49:17.571377 zmc_m1[2445].DB4-zm_rtsp.cpp/590 [Got 1028 bytes on data channel 0, packet length is 1024]
11/05/11 15:49:17.571384 zmc_m1[2445].DB4-zm_rtsp.cpp/591 [16: 24 00 04 00 80 9a c6 7e de 88 4a dc 5c 48 2a 97]
11/05/11 15:49:17.571396 zmc_m1[2445].DB5-zm_rtp_data.cpp/44 [Ver: 2]
11/05/11 15:49:17.571408 zmc_m1[2445].DB5-zm_rtp_data.cpp/45 [P: 0]
11/05/11 15:49:17.571415 zmc_m1[2445].DB5-zm_rtp_data.cpp/46 [Pt: 26]
11/05/11 15:49:17.571421 zmc_m1[2445].DB5-zm_rtp_data.cpp/47 [Mk: 1]
11/05/11 15:49:17.571427 zmc_m1[2445].DB5-zm_rtp_data.cpp/48 [Seq: 50814]
11/05/11 15:49:17.571433 zmc_m1[2445].DB5-zm_rtp_data.cpp/49 [T/S: de884adc]
11/05/11 15:49:17.571439 zmc_m1[2445].DB5-zm_rtp_data.cpp/50 [SSRC: 5c482a97]
11/05/11 15:49:17.571446 zmc_m1[2445].DB5-zm_rtp_source.cpp/87 [Seq: 50814]
11/05/11 15:49:17.571452 zmc_m1[2445].DB3-zm_rtp_source.cpp/94 [Sequence in probation 2, in sequence]
11/05/11 15:49:17.571459 zmc_m1[2445].DB4-zm_rtp_source.cpp/259 [16: 00 00 00 00 01 32 16 12 e3 22 fb a7 eb 52 54 71]
11/05/11 15:49:17.571470 zmc_m1[2445].DB4-zm_rtp_source.cpp/262 [16: 00 00 00 00 01 32 16 12 e3 22 fb a7 eb 52 54 71]
11/05/11 15:49:17.571481 zmc_m1[2445].DB2-zm_rtp_source.cpp/268 [Got new frame 0, 1012 bytes]
11/05/11 15:49:17.571492 zmc_m1[2445].DB8-zm_thread.cpp/215 [Updating value with signal, 0x77949b0]
11/05/11 15:49:17.571502 zmc_m1[2445].DB9-zm_thread.cpp/221 [Updated value, 0x77949b0]
11/05/11 15:49:17.571508 zmc_m1[2445].DB8-zm_thread.cpp/201 [Waiting for value update, 1 secs, 0x7794a18]
11/05/11 15:49:17.571515 zmc_m1[2445].DB8-zm_thread.cpp/127 [Waiting for 1 seconds]
11/05/11 15:49:17.572480 zmc_m1[2442].DB2-zm_remote_camera_rtsp.cpp/120 [Got sources]
11/05/11 15:49:17.572846 zmc_m1[2442].DB3-zm_rtp_source.cpp/312 [Getting frame]
11/05/11 15:49:17.572862 zmc_m1[2442].DB8-zm_thread.cpp/215 [Updating value with signal, 0x7794a18]
11/05/11 15:49:17.572876 zmc_m1[2442].DB9-zm_thread.cpp/221 [Updated value, 0x7794a18]
11/05/11 15:49:17.572883 zmc_m1[2442].DB3-zm_rtp_source.cpp/323 [Copied 1012 bytes]
11/05/11 15:49:17.572890 zmc_m1[2442].DB3-zm_remote_camera_rtsp.cpp/179 [Read frame 1012 bytes]
11/05/11 15:49:17.572897 zmc_m1[2442].DB4-zm_remote_camera_rtsp.cpp/180 [Address 0x7795ae0]
11/05/11 15:49:17.572903 zmc_m1[2442].DB4-zm_remote_camera_rtsp.cpp/181 [16: 00 00 00 00 01 32 16 12 e3 22 fb a7 eb 52 54 71]
11/05/11 15:49:17.572939 zmc_m1[2445].DB9-zm_thread.cpp/209 [Got value update, 0x7794a18]
11/05/11 15:49:17.572962 zmc_m1[2 [Getting frame]
11/05/11 15:49:17.652088 zmc_m1[2442].DB8-zm_thread.cpp/201 [Waiting for value update, 1 s[mjpeg @ 0x7794080] mjpeg decode frame unused 0 bytes
ecs, 0x77949b0]
11/05/11 15:49:17.652133 zmc_m1[2442].DB8-zm_thread.cpp/127 [Waiting for 1 seconds]
11/05/11 15:49:17.770917 zmc_m1[2445].DB4-zm_rtsp.cpp/573 [Read 4 bytes on sd 4, 4 total]
11/05/11 15:49:17.770938 zmc_m1[2445].DB4-zm_rtsp.cpp/582 [Got 4 bytes left, expecting 997 byte packet on channel 0]
11/05/11 15:49:17.770946 zmc_m1[2445].DB4-zm_rtsp.cpp/585 [Missing 997 bytes, rereading]
11/05/11 15:49:17.771244 zmc_m1[2445].DB4-zm_rtsp.cpp/573 [Read 997 bytes on sd 4, 1001 total]
11/05/11 15:49:17.771260 zmc_m1[2445].DB4-zm_rtsp.cpp/582 [Got 1001 bytes left, expecting 997 byte packet on channel 0]
11/05/11 15:49:17.771268 zmc_m1[2445].DB4-zm_rtsp.cpp/590 [Got 1001 bytes on data channel 0, packet length is 997]
11/05/11 15:49:17.771275 zmc_m1[2445].DB4-zm_rtsp.cpp/591 [16: 24 00 03 e5 80 9a c6 80 de 88 91 2e 5c 48 2a 97]
11/05/11 15:49:17.771286 zmc_m1[2445].DB5-zm_rtp_data.cpp/44 [Ver: 2]
11/05/11 15:49:17.771293 zmc_m1[2445].DB5-zm_rtp_data.cpp/45 [P: 0]
11/05/11 15:49:17.771303 zmc_m1[2445].DB5-zm_rtp_data.cpp/46 [Pt: 26]
11/05/11 15:49:17.771310 zmc_m1[2445].DB5-zm_rtp_data.cpp/47 [Mk: 1]
11/05/11 15:49:17.771316 zmc_m1[2445].DB5-zm_rtp_data.cpp/48 [Seq: 50816]
11/05/11 15:49:17.771323 zmc_m1[2445].DB5-zm_rtp_data.cpp/49 [T/S: de88912e]
11/05/11 15:49:17.771329 zmc_m1[2445].DB5-zm_rtp_data.cpp/50 [SSRC: 5c482a97]
11/05/11 15:49:17.771335 zmc_m1[2445].DB5-zm_rtp_source.cpp/87 [Seq: 50816]
11/05/11 15:49:17.771342 zmc_m1[2445].DB3-zm_rtp_source.cpp/117 [Packet in sequence, gap 1]
11/05/11 15:49:17.771348 zmc_m1[2445].DB4-zm_rtp_source.cpp/259 [16: 00 00 00 00 01 32 16 12 e3 22 fb 87 eb 52 54 71]
11/05/11 15:49:17.771359 zmc_m1[2445].DB4-zm_rtp_source.cpp/262 [16: 00 00 00 00 01 32 16 12 e3 22 fb 87 eb 52 54 71]
11/05/11 15:49:17.771370 zmc_m1[2445].DB2-zm_rtp_source.cpp/268 [Got new frame 2, 985 bytes]
11/05/11 15:49:17.771377 zmc_m1[2445].DB8-zm_thread.cpp/215 [Updating value with signal, 0x77949b0]
11/05/11 15:49:17.771389 zmc_m1[2445].DB9-zm_thread.cpp/221 [Updated value, 0x77949b0]
11/05/11 15:49:17.771396 zmc_m1[2445].DB8-zm_thread.cpp/201 [Waiting for value update, 1 secs, 0x7794a18]
11/05/11 15:49:17.771403 zmc_m1[2445].DB8-zm_thread.cpp/127 [Waiting for 1 seconds]
11/05/11 15:49:17.771472 zmc_m1[2442].DB9-zm_thread.cpp/209 [Got value update, 0x77949b0]
11/05/11 15:49:17.771496 zmc_m1[2442].DB8-zm_thread.cpp/215 [Updating value with signal, 0x7794a18]
11/05/11 15:49:17.771512 zmc_m1[2442].DB9-zm_thread.cpp/221 [Updated value, 0x7794a18]
11/05/11 15:49:17.771523 zmc_m1[2442].DB3-zm_rtp_source.cpp/323 [Copied 985 bytes]
11/05/11 15:49:17.771530 zmc_m1[2442].DB3-zm_remote_camera_rtsp.cpp/179 [Read frame 985 bytes]
11/05/11 15:49:17.771536 zmc_m1[2442].DB4-zm_remote_camera_rtsp.cpp/180 [Address 0x7795ae0]
11/05/11 15:49:17.771543 zmc_m1[2442].DB4-zm_remote_camera_rtsp.cpp/181 [16: 00 00 00 00 01 32 16 12 e3 22 fb 87 eb 52 54 71]
11/05/11 15:49:17.771586 zmc_m1[2442].DB2-zm_remote_camera_rtsp.cpp/230 [Frame: 0 - 985/985]
11/05/11 15:49:17.771577 zmc_m1[2445].DB9-zm_thread.cpp/209 [Got value update, 0x7794a18]
11/05/11 15:49:17.771599 zmc_m1[2442].WAR-zm_remote_camera_rtsp.cpp/258 [Unable to get picture from frame]
11/05/11 15:49:17.771601 zmc_m1[2445].DB5-zm_rtp_source.cpp/187 [RTP Jitter: 0]
11/05/11 15:49:17.771613 zmc_m1[2445].DB4-zm_rtsp.cpp/593 [Received]
11/05/11 15:49:17.772009 zmc_m1[2442].DB3-zm_rtp_source.cpp/312 [Getting frame]
11/05/11 15:49:17.772027 zmc_m1[2442].DB8-zm_thread.cpp/201 [Waiting for value update, 1 secs, 0x77949b0]
11/05/11 15:49:17.772035 zmc_m1[2442].DB8-zm_thread.cpp/127 [Waiting for 1 seconds]
11/05/11 15:49:17.850776 zmc_m1[2445].DB4-zm_rtsp.cpp/573 [Read 4 bytes on sd 4, 4 total]
11/05/11 15:49:17.850796 zmc_m1[2445].DB4-zm_rtsp.cpp/582 [Got 4 bytes left, expecting 996 byte packet on channel 0]
11/05/11 15:49:17.850805 zmc_m1[2445].DB4-zm_rtsp.cpp/585 [Missing 996 bytes, rereading]
11/05/11 15:49:17.850933 zmc_m1[2445].DB4-zm_rtsp.cpp/573 [Read 996 bytes on sd 4, 1000 total]
11/05/11 15:49:17.850945 zmc_m1[2445].DB4-zm_rtsp.cpp/582 [Got 1000 bytes left, expecting 996 byte packet[mjpeg @ 0x7794080] mjpeg decode frame unused 0 bytes
on channel 0]
11/05/11 15:49:17.850980 zmc_m1[2445].DB4-zm_rtsp.cpp/590 [Got 1000 bytes on data channel 0, packet length is 996]
11/05/11 15:49:17.850990 zmc_m1[2445].DB4-zm_rtsp.cpp/591 [16: 24 00 03 e4 80 9a c6 81 de 88 ad 42 5c 48 2a 97]
11/05/11 15:49:17.851001 zmc_m1[2445].DB5-zm_rtp_data.cpp/44 [Ver: 2]
11/05/11 15:49:17.851008 zmc_m1[2445].DB5-zm_rtp_data.cpp/45 [P: 0]
11/05/11 15:49:17.851015 zmc_m1[2445].DB5-zm_rtp_data.cpp/46 [Pt: 26]
11/05/11 15:49:17.851021 zmc_m1[2445].DB5-zm_rtp_data.cpp/47 [Mk: 1]
11/05/11 15:49:17.851027 zmc_m1[2445].DB5-zm_rtp_data.cpp/48 [Seq: 50817]
11/05/11 15:49:17.851033 zmc_m1[2445].DB5-zm_rtp_data.cpp/49 [T/S: de88ad42]
11/05/11 15:49:17.851040 zmc_m1[2445].DB5-zm_rtp_data.cpp/50 [SSRC: 5c482a97]
11/05/11 15:49:17.851050 zmc_m1[2445].DB5-zm_rtp_source.cpp/87 [Seq: 50817]
11/05/11 15:49:17.851057 zmc_m1[2445].DB3-zm_rtp_source.cpp/117 [Packet in sequence, gap 1]
11/05/11 15:49:17.851064 zmc_m1[2445].DB4-zm_rtp_source.cpp/259 [16: 00 00 00 00 01 32 16 12 e3 22 fb 87 eb 52 54 71]
11/05/11 15:49:17.851075 zmc_m1[2445].DB4-zm_rtp_source.cpp/262 [16: 00 00 00 00 01 32 16 12 e3 22 fb 87 eb 52 54 71]
11/05/11 15:49:17.851086 zmc_m1[2445].DB2-zm_rtp_source.cpp/268 [Got new frame 3, 984 bytes]
11/05/11 15:49:17.851093 zmc_m1[2445].DB8-zm_thread.cpp/215 [Updating value with signal, 0x77949b0]
11/05/11 15:49:17.851103 zmc_m1[2445].DB9-zm_thread.cpp/221 [Updated value, 0x77949b0]
11/05/11 15:49:17.851111 zmc_m1[2445].DB8-zm_thread.cpp/201 [Waiting for value update, 1 secs, 0x7794a18]
11/05/11 15:49:17.851117 zmc_m1[2445].DB8-zm_thread.cpp/127 [Waiting for 1 seconds]
11/05/11 15:49:17.851192 zmc_m1[2442].DB9-zm_thread.cpp/209 [Got value update, 0x77949b0]
11/05/11 15:49:17.851216 zmc_m1[2442].DB8-zm_thread.cpp/215 [Updating value with signal, 0x7794a18]
11/05/11 15:49:17.851232 zmc_m1[2442].DB9-zm_thread.cpp/221 [Updated value, 0x7794a18]
11/05/11 15:49:17.851243 zmc_m1[2442].DB3-zm_rtp_source.cpp/323 [Copied 984 bytes]
11/05/11 15:49:17.851249 zmc_m1[2442].DB3-zm_remote_camera_rtsp.cpp/179 [Read frame 984 bytes]
11/05/11 15:49:17.851256 zmc_m1[2442].DB4-zm_remote_camera_rtsp.cpp/180 [Address 0x7795ae0]
11/05/11 15:49:17.851262 zmc_m1[2442].DB4-zm_remote_camera_rtsp.cpp/181 [16: 00 00 00 00 01 32 16 12 e3 22 fb 87 eb 52 54 71]
11/05/11 15:49:17.851343 zmc_m1[2442].DB2-zm_remote_camera_rtsp.cpp/230 [Frame: 0 - 984/984]
11/05/11 15:49:17.851354 zmc_m1[2442].WAR-zm_remote_camera_rtsp.cpp/258 [Unable to get picture from frame]
11/05/11 15:49:17.851361 zmc_m1[2445].DB9-zm_thread.cpp/209 [Got value update, 0x7794a18]
11/05/11 15:49:17.851384 zmc_m1[2445].DB5-zm_rtp_source.cpp/187 [RTP Jitter: 0]
11/05/11 15:49:17.851395 zmc_m1[2445].DB4-zm_rtsp.cpp/593 [Received]
11/05/11 15:49:17.851723 zmc_m1[2442].DB3-zm_rtp_source.cpp/312 [Getting frame]
11/05/11 15:49:17.851740 zmc_m1[2442].DB8-zm_thread.cpp/201 [Waiting for value update, 1 secs, 0x77949b0]
11/05/11 15:49:17.851748 zmc_m1[2442].DB8-zm_thread.cpp/127 [Waiting for 1 seconds]
11/05/11 15:49:17.970887 zmc_m1[2445].DB4-zm_rtsp.cpp/573 [Read 2 bytes on sd 4, 2 total]
11/05/11 15:49:17.970908 zmc_m1[2445].DB4-zm_rtsp.cpp/582 [Got 2 bytes left, expecting 996 byte packet on channel 0]
11/05/11 15:49:17.970916 zmc_m1[2445].DB4-zm_rtsp.cpp/585 [Missing 998 bytes, rereading]
11/05/11 15:49:17.970936 zmc_m1[2445].DB4-zm_rtsp.cpp/573 [Read 2 bytes on sd 4, 4 total]
11/05/11 15:49:17.970945 zmc_m1[2445].DB4-zm_rtsp.cpp/582 [Got 4 bytes left, expecting 1042 byte packet on channel 0]
11/05/11 15:49:17.970952 zmc_m1[2445].DB4-zm_rtsp.cpp/585 [Missing 1044 bytes, rereading]
11/05/11 15:49:17.971102 zmc_m1[2445].DB4-zm_rtsp.cpp/573 [Read 1042 bytes on sd 4, 1046 total]
11/05/11 15:49:17.971120 zmc_m1[2445].DB4-zm_rtsp.cpp/582 [Got 1046 bytes left, expecting 1042 byte packet on channel 0]
11/05/11 15:49:17.971129 zmc_m1[2445].DB4-zm_rtsp.cpp/590 [Got 1046 bytes on data channel 0, packet length is 1042]
11/05/11 15:49:17.971136 zmc_m1[2445].DB4-zm_rtsp.cpp/591 [16: 24 00 04 12 80 9a c6 82 de 88 d7 7c 5c 48 2a 97]
11/05/11 15:49:17.971148 zmc_m1[2445].DB5-zm_rtp_data[mjpeg @ 0x7794080] mjpeg decode frame unused 0 bytes
.cpp/44 [Ver: 2]
11/05/11 15:49:17.971215 zmc_m1[2445].DB5-zm_rtp_data.cpp/45 [P: 0]
11/05/11 15:49:17.971225 zmc_m1[2445].DB5-zm_rtp_data.cpp/46 [Pt: 26]
11/05/11 15:49:17.971232 zmc_m1[2445].DB5-zm_rtp_data.cpp/47 [Mk: 1]
11/05/11 15:49:17.971238 zmc_m1[2445].DB5-zm_rtp_data.cpp/48 [Seq: 50818]
11/05/11 15:49:17.971244 zmc_m1[2445].DB5-zm_rtp_data.cpp/49 [T/S: de88d77c]
11/05/11 15:49:17.971251 zmc_m1[2445].DB5-zm_rtp_data.cpp/50 [SSRC: 5c482a97]
11/05/11 15:49:17.971257 zmc_m1[2445].DB5-zm_rtp_source.cpp/87 [Seq: 50818]
11/05/11 15:49:17.971264 zmc_m1[2445].DB3-zm_rtp_source.cpp/117 [Packet in sequence, gap 1]
11/05/11 15:49:17.971270 zmc_m1[2445].DB4-zm_rtp_source.cpp/259 [16: 00 00 00 00 01 32 16 12 e3 22 fb a7 eb 52 54 71]
11/05/11 15:49:17.971282 zmc_m1[2445].DB4-zm_rtp_source.cpp/262 [16: 00 00 00 00 01 32 16 12 e3 22 fb a7 eb 52 54 71]
11/05/11 15:49:17.971292 zmc_m1[2445].DB2-zm_rtp_source.cpp/268 [Got new frame 4, 1030 bytes]
11/05/11 15:49:17.971299 zmc_m1[2445].DB8-zm_thread.cpp/215 [Updating value with signal, 0x77949b0]
11/05/11 15:49:17.971310 zmc_m1[2445].DB9-zm_thread.cpp/221 [Updated value, 0x77949b0]
11/05/11 15:49:17.971317 zmc_m1[2445].DB8-zm_thread.cpp/201 [Waiting for value update, 1 secs, 0x7794a18]
11/05/11 15:49:17.971324 zmc_m1[2445].DB8-zm_thread.cpp/127 [Waiting for 1 seconds]
11/05/11 15:49:17.971397 zmc_m1[2442].DB9-zm_thread.cpp/209 [Got value update, 0x77949b0]
11/05/11 15:49:17.971420 zmc_m1[2442].DB8-zm_thread.cpp/215 [Updating value with signal, 0x7794a18]
11/05/11 15:49:17.971436 zmc_m1[2442].DB9-zm_thread.cpp/221 [Updated value, 0x7794a18]
11/05/11 15:49:17.971446 zmc_m1[2442].DB3-zm_rtp_source.cpp/323 [Copied 1030 bytes]
11/05/11 15:49:17.971453 zmc_m1[2442].DB3-zm_remote_camera_rtsp.cpp/179 [Read frame 1030 bytes]
11/05/11 15:49:17.971460 zmc_m1[2442].DB4-zm_remote_camera_rtsp.cpp/180 [Address 0x7795ae0]
11/05/11 15:49:17.971466 zmc_m1[2442].DB4-zm_remote_camera_rtsp.cpp/181 [16: 00 00 00 00 01 32 16 12 e3 22 fb a7 eb 52 54 71]
11/05/11 15:49:17.971509 zmc_m1[2442].DB2-zm_remote_camera_rtsp.cpp/230 [Frame: 0 - 1030/1030]
11/05/11 15:49:17.971519 zmc_m1[2442].WAR-zm_remote_camera_rtsp.cpp/258 [Unable to get picture from frame]
11/05/11 15:49:17.971791 zmc_m1[2445].DB9-zm_thread.cpp/209 [Got value update, 0x7794a18]
11/05/11 15:49:17.971812 zmc_m1[2445].DB5-zm_rtp_source.cpp/187 [RTP Jitter: 0]
11/05/11 15:49:17.971820 zmc_m1[2445].DB4-zm_rtsp.cpp/593 [Received]
11/05/11 15:49:17.971923 zmc_m1[2442].DB3-zm_rtp_source.cpp/312 [Getting frame]
11/05/11 15:49:17.971940 zmc_m1[2442].DB8-zm_thread.cpp/201 [Waiting for value update, 1 secs, 0x77949b0]
11/05/11 15:49:17.971949 zmc_m1[2442].DB8-zm_thread.cpp/127 [Waiting for 1 seconds]
11/05/11 15:49:18.050899 zmc_m1[2445].DB4-zm_rtsp.cpp/573 [Read 4 bytes on sd 4, 4 total]
11/05/11 15:49:18.050920 zmc_m1[2445].DB4-zm_rtsp.cpp/582 [Got 4 bytes left, expecting 1035 byte packet on channel 0]
11/05/11 15:49:18.050929 zmc_m1[2445].DB4-zm_rtsp.cpp/585 [Missing 1035 bytes, rereading]
11/05/11 15:49:18.051113 zmc_m1[2445].DB4-zm_rtsp.cpp/573 [Read 1035 bytes on sd 4, 1039 total]
11/05/11 15:49:18.051131 zmc_m1[2445].DB4-zm_rtsp.cpp/582 [Got 1039 bytes left, expecting 1035 byte packet on channel 0]
11/05/11 15:49:18.051141 zmc_m1[2445].DB4-zm_rtsp.cpp/590 [Got 1039 bytes on data channel 0, packet length is 1035]
11/05/11 15:49:18.051148 zmc_m1[2445].DB4-zm_rtsp.cpp/591 [16: 24 00 04 0b 80 9a c6 83 de 88 f3 9d 5c 48 2a 97]
11/05/11 15:49:18.051190 zmc_m1[2445].DB5-zm_rtp_data.cpp/44 [Ver: 2]
11/05/11 15:49:18.051199 zmc_m1[2445].DB5-zm_rtp_data.cpp/45 [P: 0]
11/05/11 15:49:18.051205 zmc_m1[2445].DB5-zm_rtp_data.cpp/46 [Pt: 26]
11/05/11 15:49:18.051211 zmc_m1[2445].DB5-zm_rtp_data.cpp/47 [Mk: 1]
11/05/11 15:49:18.051217 zmc_m1[2445].DB5-zm_rtp_data.cpp/48 [Seq: 50819]
11/05/11 15:49:18.051223 zmc_m1[2445].DB5-zm_rtp_data.cpp/49 [T/S: de88f39d]
11/05/11 15:49:18.051230 zmc_m1[2445].DB5-zm_rtp_data.cpp/50 [SSRC: 5c482a97]
11/05/11 15:49:18.051236 zmc_m1[2445].DB5-zm_rtp_source.cpp/87 [Seq: 50819]
11/05/11 15:49:18.051243 zmc_m1[2445].DB3-zm_rtp_source.c[mjpeg @ 0x7794080] mjpeg decode frame unused 0 bytes
11/05/11 15:49:18.051276 zmc_m1[2445].DB4-zm_rtp_source.cpp/259 [16: 00 00 00 00 01 32 16 12 e3 22 fb a7 eb 52 54 71]
11/05/11 15:49:18.051291 zmc_m1[2445].DB4-zm_rtp_source.cpp/262 [16: 00 00 00 00 01 32 16 12 e3 22 fb a7 eb 52 54 71]
11/05/11 15:49:18.051302 zmc_m1[2445].DB2-zm_rtp_source.cpp/268 [Got new frame 5, 1023 bytes]
11/05/11 15:49:18.051309 zmc_m1[2445].DB8-zm_thread.cpp/215 [Updating value with signal, 0x77949b0]
11/05/11 15:49:18.051336 zmc_m1[2445].DB9-zm_thread.cpp/221 [Updated value, 0x77949b0]
11/05/11 15:49:18.051343 zmc_m1[2445].DB8-zm_thread.cpp/201 [Waiting for value update, 1 secs, 0x7794a18]
11/05/11 15:49:18.051350 zmc_m1[2445].DB8-zm_thread.cpp/127 [Waiting for 1 seconds]
11/05/11 15:49:18.051429 zmc_m1[2442].DB9-zm_thread.cpp/209 [Got value update, 0x77949b0]
11/05/11 15:49:18.051453 zmc_m1[2442].DB8-zm_thread.cpp/215 [Updating value with signal, 0x7794a18]
11/05/11 15:49:18.051469 zmc_m1[2442].DB9-zm_thread.cpp/221 [Updated value, 0x7794a18]
11/05/11 15:49:18.051479 zmc_m1[2442].DB3-zm_rtp_source.cpp/323 [Copied 1023 bytes]
11/05/11 15:49:18.051486 zmc_m1[2442].DB3-zm_remote_camera_rtsp.cpp/179 [Read frame 1023 bytes]
11/05/11 15:49:18.051493 zmc_m1[2442].DB4-zm_remote_camera_rtsp.cpp/180 [Address 0x7795ae0]
11/05/11 15:49:18.051500 zmc_m1[2442].DB4-zm_remote_camera_rtsp.cpp/181 [16: 00 00 00 00 01 32 16 12 e3 22 fb a7 eb 52 54 71]
11/05/11 15:49:18.051542 zmc_m1[2442].DB2-zm_remote_camera_rtsp.cpp/230 [Frame: 0 - 1023/1023]
11/05/11 15:49:18.051552 zmc_m1[2442].WAR-zm_remote_camera_rtsp.cpp/258 [Unable to get picture from frame]
11/05/11 15:49:18.051553 zmc_m1[2445].DB9-zm_thread.cpp/209 [Got value update, 0x7794a18]
11/05/11 15:49:18.051578 zmc_m1[2445].DB5-zm_rtp_source.cpp/187 [RTP Jitter: 0]
What can I do to have this camera working with ZM?
Thank you
josh
