U Server 11.10 64bit, ZM 1.25 source, libjpeg-turbo, Cambozo
Posted: Tue Nov 15, 2011 3:07 pm
This is not mine. I use this: http://www.zoneminder.com/wiki/index.ph ... _Cambozola and this: http://www.zoneminder.com/wiki/index.ph ... t)_Desktop then I cut and paste. Because I cut and paste, some packets, ZM don't need it.
My dvr card like this: http://www.zoneminder.com/wiki/index.php/Kodicom_8800
Install new box with Ubuntu server 11.10 64bit. At software selection, select OpenSSH.
Create root account:
And later do everything with root too.
Set static IP:
Cut and paste this quote into file:
Restart NIC:
Update system software:
Install bttv driver:
Do something for Zoneminder:
Install Webmin:
Install libjpeg-turbo (AMD64):
Configure Lib Paths:
Install Perl Modules:
Install FFmpeg:
Install Zoneminder:
Password that is requested is Mysql root password that was entered during install, not your ubuntu password.
Install Cambozola:
Create Zoneminder startup script:
Paste everything BETWEEN the lines below.
Zoneminder Startup:
In firefox, go to https://YOUR_ZoneMinder.IP.ADDRESS.HERE:10000 to reach the Webmin interface.(Login with Ubuntu username and password)
In left menu, select System>Bootup and Shutdown. Tick the box next to zm and click StartNow and On Boot.
In left menu, select Servers>Apache Webserver. Click virtual server under Existing virtual hosts tab. Under Virtual Server Details, change Document Root to /var/www/zm and then save.
Click apply changes at top left of page.
Go to http://YOUR_ZoneMinder.IP.ADDRESS.HERE to reach the Zoneminder interface.
If you want better quality video, cut -r 25 in Option->Images->FFMPEG_OUTPUT_OPTIONS ad replace with:
sudo passwd root
Set static IP:
nano /etc/network/interfaces
ctrl-o to save ctrl-x to exit nano# The primary network interface
auto eth0
iface eth0 inet static
address 192.168.1.10
netmask 255.255.255.0
gateway 192.168.1.1
Restart NIC:
sudo ifdown -a
sudo ifup -a
sudo apt-get update
sudo apt-get upgrade
nano /etc/modprobe.d/bttv.conf
Reboot box:options i2c-algo-bit bit_test=1
options bttv gbuffers=16 card=102,102,102,102,102,102,102,102 radio=0,0,0,0,0,0,0,0 tuner=4,4,4,4,4,4,4,4 chroma_agc=1 combfilter=2 full_luma_range=1 coring=1 autoload=0
reboot
export CFLAGS="-march=native -O2 -pipe" && export CXXFLAGS="${CFLAGS}" && export CPPFLAGS="${CFLAGS}"
aptitude install acpid build-essential linux-headers-`uname -r` automake perl libauthen-pam-perl apache2 libpam-runtime libio-pty-perl libmysqlclient-dev php5 php5-cli libapache2-mod-php5 php5-mysql libarchive-zip-perl libdate-manip-perl libdevice-serialport-perl libjpeg62 libmime-perl libstdc++6 libwww-perl zlib1g zip unzip patch ntp openssl libpcre3-dev libssl-dev libjpeg-progs libcurl4-gnutls-dev munin munin-node libmime-lite-perl netpbm libbz2-dev subversion yasm libnet-ssleay-perl libauthen-pam-perl libio-pty-perl apt-show-versions git-core mysql-server mysql-client mc htop -y
apt-get install libmysqlclient-dev libjpeg-dev libpcre3-dev build-essential -y
wget http://downloads.sourceforge.net/project/webadmin/webmin/1.570/webmin_1.570_all.deb?use_mirror=voxel
mv webmin_1.570_all.deb\?use_mirror=voxel webmin_1.570_all.deb && dpkg -i webmin_1.570_all.deb
wget http://downloads.sourceforge.net/project/libjpeg-turbo/1.1.1/libjpeg-turbo_1.1.1_amd64.deb?use_mirror=voxel
mv libjpeg-turbo_1.1.1_amd64.deb?use_mirror=voxel libjpeg-turbo_1.1.1_amd64.deb && dpkg -i libjpeg-turbo_1.1.1_amd64.deb
ln -s /opt/libjpeg-turbo/lib/libjpeg.a /usr/lib/libjpeg.a && ln -s /opt/libjpeg-turbo/include/jconfig.h /usr/include/jconfig.h && ln -s /opt/libjpeg-turbo/include/jerror.h /usr/include/jerror.h && ln -s /opt/libjpeg-turbo/include/jmorecfg.h /usr/include/jmorecfg.h && ln -s /opt/libjpeg-turbo/include/jpeglib.h /usr/include/jpeglib.h
echo "/opt/libjpeg-turbo/lib" > /etc/ld.so.conf.d/libjpeg-turbo.conf && echo "/usr/local/lib" > /etc/ld.so.conf.d/ffmpeg.conf && echo "LD_LIBRARY_PATH=/usr/local/lib:/opt/libjpeg-turbo/lib:$LD_LIBRARY_PATH" >> /etc/bash.bashrc && echo "export LD_LIBRARY_PATH" >> /etc/bash.bashrc
ldconfig
perl -MCPAN -e shell
install CPAN
exit
install YAML PHP::Serialization Module::Load X10::ActiveHome
exit
install Sys::Mmap
install DBI
install DBD::mysql
install Date::Manip
install PHP::Serialization
exit
apt-get install ffmpeg -y
Install Zoneminder:
cd /usr/src && svn co http://svn.zoneminder.com/svn/zm/trunk zm
cd /usr/src/zm && ./configure --with-webdir=/var/www/zm --with-cgidir=/usr/lib/cgi-bin ZM_DB_HOST=localhost ZM_DB_NAME=zm ZM_DB_USER=zmuser ZM_DB_PASS=zmpass ZM_SSL_LIB=openssl --enable-debug=no --with-webgroup=www-data --with-webuser=www-data --enable-mmap=yes CPPFLAGS="-D__STDC_CONSTANT_MACROS ${CPPFLAGS}"
autoconf
aclocal
automake
make
mysql -u root -p < db/zm_create.sql
mysql -u root -p
grant select,insert,update,delete on zm.* to 'zmuser'@localhost identified by 'zmpass';
quit
mysqladmin -p reload
make install
cd /usr/src && wget http://www.charliemouse.com:8080/code/cambozola/cambozola-latest.tar.gz
tar -xzvf cambozola-latest.tar.gz
cp cambozola-0.92/dist/cambozola.jar /var/www/zm
nano -w /etc/init.d/zm
ctrl-o to save, ctrl-x to exit nano#!/bin/sh
# description: Control ZoneMinder as a Service
# chkconfig: 2345 99 99
# Source function library.
#. /etc/rc.d/init.d/functions
prog=ZoneMinder
ZM_PATH_BIN="/usr/local/bin"
command="$ZM_PATH_BIN/zmpkg.pl"
start() {
echo -n "Starting $prog: "
$command start
RETVAL=$?
[ $RETVAL = 0 ] && echo success
[ $RETVAL != 0 ] && echo failure
return $RETVAL
stop() {
echo -n "Stopping $prog: "
$command stop
RETVAL=$?
status() {
result=`$command status`
if [ "$result" = "running" ]; then
echo "ZoneMinder is running"
RETVAL=0
else
echo "ZoneMinder is stopped"
RETVAL=1
fi
case "$1" in
'start')
start
'stop')
stop
'restart')
stop
start
'status')
status
echo "Usage: $0 { start | stop | restart | status }"
RETVAL=1
esac
exit $RETVAL
chmod 755 /etc/init.d/zm
Note: If you add New Monitor by hand, when you restart box, only Monitor 1 be green, monitor 2,3,4,5,6,7,8 still red. If you add New Monitor by Presets->BTTV Video (V4L2), PAL, 320x240->Save, everything works OK.-f mp4 -r 25 -b 2048k -vcodec mpeg4
