Same feed showing on multiple channels? pv-981 card.
When setting up different cameras with Zoneminder all feeds for /dev/video1 on channels 0-3 are all the same feed, even though there are different cameras connected. What is the problem here? They channels all seem to work fine by themselves.
Re: Same feed showing on multiple channels? pv-981 card.
Common problem, simple answer: Set options::config::CAPTURES_PER_FRAME to a value of 2. should clear your issue. If not then look to V4L_MULTI_BUFFER and uncheck; good luck.
