Can't start Zoneminder
thelight
Post by thelight »
I can't seem to start zoneminder. Running on CentOS6.
I have added a monitor, but when I attempt to start monitoring from the web interface it fails to start, with the error log saying:
2011-11-18 20:43:38.517720 zmpkg 1649 FAT Can't create missing temporary directory '/tmp/zm': File exists zmpkg.pl
I've looked on google and searched this forum and can't seem to find anyone with the same problem.
thelight
Re: Can't start Zoneminder
Post by thelight »
bump
elbek
Post by elbek »
did you try with:
chown www-data:www-data -R /tmp/zm
thelight
Post by thelight »
I get:
chown: invalid user: `www-data:www-data'
thanks
Simon
clipo
Post by clipo »
Try and disable SELinux
http://wiki.centos.org/HowTos/SELinux
I had the same problem and its solved it for me, now I’m looking for a mod to allow SELinux to work again.
dhanasekar
Post by dhanasekar »
thelight wrote:I get:
thanks
Simon
try using ./configure --with-webdir=/var/www/zm --with-cgidir=/var/www/cgi-bin --enable-mmap=no --with-webuser=www-data --with-webgroup=www-data
because in squeeze distribution apache replaced with www-data but even though apache is used by some processes of squeeze distribution.
thelight
Post by thelight »
disabling selinux worked, thanks very much!
