Hi there, hope this is the correct place to post this..
Ive been using ZM 124.2 now for quite a while, its been rock stable on my Ubuntu 10.04 server..
Recently bought eyezm for me iPhone to view cam feeds but when I installed the p2fs3 script i get the following errors:
Checking for availability of FFMPEG...
FFMPEG found in /usr/bin/ffmpeg
Found MPEG-4 support with older version of FFMPEG using -codecs tag
Libx264 not found with ffmpeg. Continuing install, but H264 support will not be available
Checking for zm.conf in /usr/local/etc/zm/zm.conf
Checking for zm.conf in /usr/local/zm/zm.conf
Checking for zm.conf in /etc/zm/zm.conf
Found ZM configuration file in /etc/zm/zm.conf
ZM Web base is in /usr/share/zoneminder, server version 1.24.2
Version number OK
/usr/share/zoneminder/skins/xml does not exist, creating directory...
Installing files as user root and group root to /usr/share/zoneminder/skins
Copying XML Plugin...
cp: cannot create directory `/usr/share/zoneminder/skins/xml': Permission denied
chown: changing ownership of `/usr/share/zoneminder/skins/classic/lang': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/css/control.css': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/css/export.css': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/css/skin.css': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/css': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/skin.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/includes/control_functions.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/includes/functions.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/includes/init.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/includes/timeline_functions.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/includes/export_functions.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/includes/config.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/includes': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/monitorpreset.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/console.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/group.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/bandwidth.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/video.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/cycle.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/device.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/monitor.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/events.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/settings.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/state.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/watch.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/none.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/options.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/css/control.css': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/css/event.css': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/css/frame.css': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/css/devices.css': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/css/montage_freeform.css': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/css/export.css': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/css/controlcaps.css': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/css/events.css': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/css/frames.css': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/css/montage.css': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/css/groups.css': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/css/zone.css': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/css/montage_3wide.css': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/css/video.css': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/css/timeline.css': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/css/montage_3wide50enlarge.css': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/css/filter.css': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/css/montage_4wide.css': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/css/monitor.css': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/css/options.css': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/css/console.css': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/css/montage_2wide.css': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/css/stats.css': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/css/timeline.css.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/css/watch.css': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/css': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/event.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/eventdetail.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/status.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/zone.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/monitorprobe.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/logout.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/filter.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/controlcap.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/frame.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/donate.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/Makefile.am': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/controlcaps.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/error.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/user.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/frames.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/devices.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/postlogin.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/blank.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/zones.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/function.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/stats.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/monitorprobe.js': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/cycle.js': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/events.js': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/donate.js.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/export.js': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/controlpreset.js.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/version.js': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/export.js.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/events.js.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/group.js': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/state.js': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/video.js': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/monitorpreset.js': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/zone.js.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/options.js.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/cycle.js.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/event.js.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/state.js.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/Makefile.am': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/zone.js': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/monitor.js.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/filter.js.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/devices.js': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/console.js.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/version.js.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/user.js': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/watch.js.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/filter.js': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/timeline.js.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/montage.js': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/watch.js': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/video.js.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/groups.js': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/monitor.js': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/montage.js.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/login.js': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/controlpreset.js': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/postlogin.js': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/event.js': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/control.js': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/donate.js': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/timeline.js': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js/console.js': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/js': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/controlpreset.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/control.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/filtersave.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/login.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/export.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/timeline.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/groups.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/montage.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/version.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views/optionhelp.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/views': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/ajax': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/js/skin.js.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/js/skin.js': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/js': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/graphics/arrow-dr.gif': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/graphics/arrow-u.gif': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/graphics/point-o.gif': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/graphics/arrow-ur.gif': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/graphics/arrow-l-d.gif': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/graphics/arrow-ul.gif': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/graphics/point-g.gif': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/graphics/center.gif': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/graphics/seq-u.gif': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/graphics/arrow-d.gif': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/graphics/seq-d.gif': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/graphics/arrow-l.gif': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/graphics/point-r.gif': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/graphics/arrow-r.gif': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/graphics/arrow-dl.gif': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/graphics/arrow-l-u.gif': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic/graphics': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/classic': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/mobile/lang': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/mobile/css/skin.css': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/mobile/css': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/mobile/skin.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/mobile/includes/functions.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/mobile/includes/init.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/mobile/includes/config.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/mobile/includes': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/mobile/views/console.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/mobile/views/video.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/mobile/views/events.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/mobile/views/state.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/mobile/views/watch.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/mobile/views/css/console.css': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/mobile/views/css': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/mobile/views/event.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/mobile/views/filter.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/mobile/views/frame.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/mobile/views/error.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/mobile/views/devices.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/mobile/views/function.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/mobile/views/login.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/mobile/views/montage.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/mobile/views/eventdetails.php': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/mobile/views': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/mobile/ajax': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/mobile/graphics': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins/mobile': Operation not permitted
chown: changing ownership of `/usr/share/zoneminder/skins': Operation not permitted
Located PHP5-GD package, no need to install
Now, obviously a permission/ownership issue yes? Seems like the installer cant create,modify files and directories
All the files/directories that cant be chowned or created are showing when I go to usr/share/zoneminder in terminal
I tried to install the script as root and the initial zoneminder install was done as root. When I look at the eyezm debug it says it sees the server but the xml isnt installed
Can anyone give me a pointer as to what went wrong here? Ive got a feeling its something simple but I cant see it...
(SOLVED) eyezm installation problem on ZM 124.2
Re: eyezm installation problem on ZM 124.2
..Ill get me coat....
Great work on eyezm BTW
