Page 1 of 1
modect question
Posted: Wed Nov 30, 2011 2:49 pm
by Snaki4
Good afternoon,
Is there any possibility to add delay for modect recording, like drop all frames 1 min before and 1 min after movement detected?
Thanks.
Re: modect question
Posted: Thu Dec 01, 2011 2:34 am
by bb99
Try lowering the pre and post buffers on the buffer tab of the monitor. Could be 0/0 is what your looking for although not very practical. You will end up with many events where only one was before and your first frame will be the motion that triggers the alarm. Play with those settings to get what you want.
Re: modect question
Posted: Wed Dec 07, 2011 12:50 pm
by Snaki4
bb99 wrote:Try lowering the pre and post buffers on the buffer tab of the monitor. Could be 0/0 is what your looking for although not very practical. You will end up with many events where only one was before and your first frame will be the motion that triggers the alarm. Play with those settings to get what you want.
Thanks for the help
Re: modect question
Posted: Thu Dec 08, 2011 3:54 am
by bb99
You're very welcome! What settings did you settle for? Could be very helpful for others searching the forums with a similar question.
