Page 1 of 1
webcam not working [fixed]
Posted: Tue Dec 06, 2011 3:12 pm
by deathguppie
I have a logitech usb webcam I am trying to test zoneminder with, the camera works, but does not show up in zoneminder.
here is the last few lines of zmdc.log
12/06/11 06:42:49.089638 zmdc[1438].INF [Starting pending process, zmc -d /dev/video0]
12/06/11 06:42:49.091405 zmdc[1438].INF ['zmc -d /dev/video0' starting at 11/12/06 06:42:49, pid = 1762]
12/06/11 06:42:49.107212 zmdc[1438].ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
12/06/11 06:43:00.032685 zmdc[1438].INF [Starting pending process, zmc -d /dev/video]
12/06/11 06:43:00.034410 zmdc[1438].INF ['zmc -d /dev/video' starting at 11/12/06 06:43:00, pid = 1772]
12/06/11 06:43:00.057395 zmdc[1438].INF ['zmc -d /dev/video' crashed, signal 6]
12/06/11 06:45:34.313151 zmdc[1438].INF ['zmfilter.pl ' exited, signal 14]
12/06/11 06:45:34.313645 zmdc[1438].INF ['zmaudit.pl -c' exited, signal 14]
12/06/11 06:45:34.313926 zmdc[1438].INF ['zmupdate.pl -c' stopping at 11/12/06 06:45:34]
12/06/11 06:45:34.317802 zmdc[1438].INF ['zmupdate.pl -c' exited, signal 14]
12/06/11 06:45:34.318364 zmdc[1438].INF ['zmwatch.pl ' stopping at 11/12/06 06:45:34]
12/06/11 06:45:34.320333 zmdc[1438].INF ['zmwatch.pl ' exited, signal 14]
This is the part I figure is wrong in zmwatch.log
12/05/11 20:34:32.371533 zmwatch[1479].ERR [Can't open memory map file '/dev/shm/zm.mmap.2': No such file or directory]
I found a reference to the issue on the web.
zoneminder package not ready to use /run
But it looks as if /run/shm already exists, owned by root with some pulse audio usage. ..
How do I fix this issue?
Re: webcam not working
Posted: Tue Dec 06, 2011 3:19 pm
by leeroybrown
Do you have the mode set to PAL ? My Logitech orbit will only work when set to PAL and does not when set to NTSC.
Posted: Tue Dec 06, 2011 8:30 pm
by deathguppie
Yes it's set to pal.. the issue is this memory thing there should be a fi
le for am in /run/
Posted: Wed Dec 07, 2011 1:58 am
by deathguppie
so I set the buffer size and alert image size to low values to see if that would help .. restarted zoneminder and get this
Dec  6 17:53:07 deathguppie-desktop zmdc[29530]: INF [Starting pending process, zmc -d /dev/video]
Dec  6 17:53:07 deathguppie-desktop zmdc[29530]: INF ['zmc -d /dev/video' starting at 11/12/06 17:53:07, pid = 29842]
Dec  6 17:53:07 deathguppie-desktop zmdc[29842]: INF ['zmc -d /dev/video' started at 11/12/06 17:53:07]
Dec  6 17:53:07 deathguppie-desktop zmc_dvideo[29842]: INF [Debug Level = 0, Debug Log = <none>]
Dec  6 17:53:07 deathguppie-desktop zmc_dvideo[29842]: PNC [Zone 3/All for monitor monitor-monitor extends outside of image dimensions, -319, 0, 0, 0]
Dec  6 17:53:07 deathguppie-desktop zmdc[29530]: INF ['zmc -d /dev/video' crashed, signal 6]
Posted: Wed Dec 07, 2011 5:03 am
by deathguppie
ok.. wow.. I've tried 3 different cameras, all of them work with xawtv and nothing.
I'm starting to realize that zoneminder for all practical purposes simply does not work. Perl is a deep well as it is, and trying to figure out why it isn't working is turning out to be almost impossible. Memory is not mapping that much I can see.. but why?
No help and running out of things to try..
Posted: Fri Dec 09, 2011 2:35 pm
by deathguppie
Figured it out. The problem was that the ubuntu package does not install perl mmap. (though it claims to) that must be done by hand. Also since I had configured the cameras prior to having mmap installed, I had to delete the existing monitors and start over before they started working.
Re: webcam not working [fixed]
Posted: Wed Feb 22, 2012 10:54 pm
by frednet
It looks like I may have the same problem on Mythbuntu 11.10, I get this error
22/02/12 22:26:42.096129 zmdc[18088].INF [Starting pending process, zmc -d /dev/video0]
22/02/12 22:26:42.098011 zmdc[18088].INF ['zmc -d /dev/video0' starting at 12/02/22 22:26:42, pid = 18129]
22/02/12 22:26:42.134714 zmdc[18088].INF ['zmc -d /dev/video0' crashed, signal 6]
22/02/12 22:26:47.210514 zmdc[18088].INF ['zmupdate.pl -c' stopping at 12/02/22 22:26:47]
22/02/12 22:26:47.215427 zmdc[18088].INF ['zmupdate.pl -c' exited, signal 14]
22/02/12 22:26:47.215680 zmdc[18088].INF ['zmwatch.pl ' stopping at 12/02/22 22:26:47]
22/02/12 22:26:47.217490 zmdc[18088].INF ['zmwatch.pl ' exited, signal 14]
22/02/12 22:26:47.218066 zmdc[18088].INF ['zma -m 5' stopping at 12/02/22 22:26:47]
22/02/12 22:26:47.219633 zmdc[18088].INF ['zma -m 5' exited, signal 14]
22/02/12 22:26:47.220110 zmdc[18088].INF ['zmaudit.pl -c' stopping at 12/02/22 22:26:47]
22/02/12 22:26:47.224205 zmdc[18088].INF ['zmaudit.pl -c' exited, signal 14]
22/02/12 22:26:47.224686 zmdc[18088].INF ['zmfilter.pl ' stopping at 12/02/22 22:26:47]
22/02/12 22:26:47.230944 zmdc[18088].INF ['zmfilter.pl ' exited, signal 14]
and also
2/02/12 21:47:27.752103 zmwatch[30527].ERR [Can't open memory map file '/dev/shm/zm.mmap.5': No such file or directory]
22/02/12 21:47:37.753523 zmwatch[30527].ERR [Can't open memory map file '/dev/shm/zm.mmap.5': No such file or directory]
22/02/12 21:47:47.754893 zmwatch[30527].ERR [Can't open memory map file '/dev/shm/zm.mmap.5': No such file or directory]
22/02/12 21:47:57.756510 zmwatch[30527].ERR [Can't open memory map file '/dev/shm/zm.mmap.5': No such file or directory]
22/02/12 22:26:37.978672 zmwatch[18124].INF [Watchdog starting]
What is the actual package missing? I've tried looking for perl-mmap but it doesn't exist.
