Can anyone recommend a PoE network camera?
wesleyw
Post by wesleyw »
That allows full control via ZoneMinder and allows ZoneMinder to record only when motion is detected?
Wes
compdoc
Re: Can anyone recommend a PoE network camera?
Post by compdoc »
There are many. Axis makes some very nice (and expensive) models like the P3344, which is an outdoor cam with a built in heater and has excellent low-light ability. But be careful - Axis also makes cams that arent very good, like the M3011.
I recently got a D-Link MCS-6111 that is POE and has a great picture, but you have to manual focus and zoom initialy. However, once its in focus, everything in range that it sees is in focus.
wesleyw
Post by wesleyw »
Does Zoneminder motion detection work well with your D-Link or is it the D-Link that does the motion detection.
Wes
compdoc
Post by compdoc »
Many cameras can do motion detection and save files to a network share, but if you do it that way there's no need to use zoneminder.
I have zoneminder doing the detection.
By the way, the D-Link MCS-6111 is an indoor cam...
AngstHab
Post by AngstHab »
We use Vivotek 8330 Kameras with Motiondedection and HD!
AngstHab
