Page 1 of 1
Can anyone recommend a PoE network camera?
Posted: Tue Dec 06, 2011 4:21 pm
by wesleyw
That allows full control via ZoneMinder and allows ZoneMinder to record only when motion is detected?
Wes
Re: Can anyone recommend a PoE network camera?
Posted: Tue Dec 13, 2011 9:21 am
by compdoc
There are many. Axis makes some very nice (and expensive) models like the P3344, which is an outdoor cam with a built in heater and has excellent low-light ability. But be careful - Axis also makes cams that arent very good, like the M3011.
I recently got a D-Link MCS-6111 that is POE and has a great picture, but you have to manual focus and zoom initialy. However, once its in focus, everything in range that it sees is in focus.
Posted: Tue Dec 13, 2011 9:31 am
by wesleyw
Does Zoneminder motion detection work well with your D-Link or is it the D-Link that does the motion detection.
Wes
Posted: Tue Dec 13, 2011 6:37 pm
by compdoc
Many cameras can do motion detection and save files to a network share, but if you do it that way there's no need to use zoneminder.
I have zoneminder doing the detection.
By the way, the D-Link MCS-6111 is an indoor cam...
Posted: Wed Dec 14, 2011 1:28 pm
by AngstHab
We use Vivotek 8330 Kameras with Motiondedection and HD!
AngstHab
