Page 1 of 1
Centos 6.0 64-bit with ZM 1.25.0, FFmpeg, libjpeg-turbo,Camb
Posted: Wed Dec 14, 2011 7:26 am
by letsharehowto
Centos 6.0 64-bit with ZoneMinder 1.25.0, FFmpeg, libjpeg-turbo, Cambozola.
Install fresh Centos 6.0 64-bit to box. REMEMBER config nic when you install.
Reboot box after install. Logon with root and then do everything with root too.
Install required packages, other useful packages, and their dependencies:
yum -y update
yum -y groupinstall core
yum -y groupinstall base
wget http://apt.sw.be/redhat/el6/en/x86_64/rpmforge/RPMS/rpmforge-release-0.5.2-2.el6.rf.x86_64.rpm
rpm --import http://apt.sw.be/RPM-GPG-KEY.dag.txt
rpm -i rpmforge-release-0.5.2-2.el6.rf.*.rpm
yum -y update
yum install -y gcc gcc-c++ bison mysql-devel mysql-server php php-mysql php-pear php-pear-DB php-mbstring tftp-server httpd make ncurses-devel libtermcap-devel sendmail sendmail-cf caching-nameserver sox newt-devel libxml2-devel libtiff-devel php-gd audiofile-devel gtk2-devel subversion kernel-devel bison-devel zlib-devel openssl-devel gnutls-devel php-process perl-Time-HiRes pcre-devel gd mod_ssl ImageMagick libjpeg-devel perl-Archive-Tar perl-MIME-Lite perl-MIME-tools perl-Date-Manip perl-PHP-Serialization perl-Device-SerialPort perl-Archive-Zip perl-Sys-Mmap perl-Module-Load git yasm cpan mc htop
Install Perl Modules:
cpan -i LWP::UserAgent
You have to say a lot of yes.
Install bttv driver- follow this step only if your card is not detected:
My card like this: http://www.zoneminder.com/wiki/index.php/Kodicom_8800
nano /etc/modprobe.d/bttv.conf
Cut and paste this quote into file:
options i2c-algo-bit bit_test=1
options bttv gbuffers=16 card=102,102,102,102,102,102,102,102 radio=0,0,0,0,0,0,0,0 tuner=4,4,4,4,4,4,4,4 chroma_agc=1 combfilter=2 full_luma_range=1 coring=1 autoload=0
After editing in nano, hit ctrl-o to save, hit enter to use the given name, then hit ctrl-x to exit nano
Disabled firewall:
setup
Go into the "Firewall Configuration" disable the Security Level click OK to save then click Quit to quit.
Disabled SELINUX:
nano /etc/selinux/config
Change from SELINUX=enforcing to SELINUX=disabled
Install ffmpeg:
git clone git://git.videolan.org/ffmpeg.git
cd ffmpeg && ./configure --enable-gpl --enable-shared --enable-pthreads
make
make install
make install-libs
cd /lib && ln -s /usr/local/lib/libswscale.so.0 && ln -s /usr/local/lib/libswresample.so.0 && ln -s /usr/local/lib/libavformat.so.52 && ln -s /usr/local/lib/libavcodec.so.52 && ln -s /usr/local/lib/libavutil.so.50 && ln -s /usr/local/lib/libavdevice.so.52 && ln -s /usr/local/lib/libavdevice.so.53 && ln -s /usr/local/lib/libavfilter.so.2 && ln -s /usr/local/lib/libavformat.so.53 && ln -s /usr/local/lib/libavcodec.so.53 && ln -s /usr/local/lib/libpostproc.so.51 && ln -s /usr/local/lib/libswscale.so.2 && ln -s /usr/local/lib/libavutil.so.51
ldconfig
Install libjpeg-turbo (64)
cd && wget http://sourceforge.net/projects/libjpeg-turbo/files/1.1.1/libjpeg-turbo-1.1.1.x86_64.rpm/download
rpm -i libjpeg-turbo-1.1.1.x86_64.rpm && nano /etc/ld.so.conf.d/libjpeg-turbo.conf
/opt/libjpeg-turbo/lib64
ldconfig
Enable services, turn everything on:
chkconfig httpd on
chkconfig mysqld on
chkconfig ntpd on
service httpd start
service mysqld start
service ntpd start
Install Zoneminder. Download ZoneMinder 1.25.0:
cd && wget http://www2.zoneminder.com/downloads/ZoneMinder-1.25.0.tar.gz
tar -zxvf ZoneMinder-1.25.0.tar.gz && cd ZoneMinder-1.25.0
CFLAGS="-g -O3 -march=native -mtune=native" CXXFLAGS="-D__STDC_CONSTANT_MACROS -g -O3 -march=native -mtune=native" ./configure  --with-extralibs="-L/usr/lib64 -L/usr/lib64/mysql" --with-webdir=/var/www/html/zm --with-cgidir=/var/www/cgi-bin --with-webuser=apache --with-webgroup=apache ZM_DB_HOST=localhost ZM_DB_NAME=zm ZM_DB_USER=zmuser ZM_DB_PASS=zmpass ZM_SSL_LIB=openssl
make
make install
Configure MySQL
Need to add a password for the root user of MySQL (in my case password is: 111111)
Create the zm database
Create the zm database user with permissions and password
mysql
SET PASSWORD FOR root@localhost=PASSWORD('111111');
create database zm;
CREATE USER 'zmuser'@'localhost' IDENTIFIED BY 'zmpass';
Query OK, 0 rows affected (0.01 sec)
grant CREATE, INSERT, SELECT, DELETE, UPDATE on zm.* to zmuser@localhost;
exit
>Bye
Import the tables into the zm database
mysql -u root -p zm < db/zm_create.sql
Type 111111 then press Enter.
Make it so that ZoneMinder will startup automatically when the system is rebooted
cp scripts/zm /etc/init.d/
chmod +x /etc/init.d/zm
chkconfig zm on
Install Cambozola:
cd && wget http://www.zoneminder.com/sites/zoneminder.com/downloads/cambozola.jar
Make sure you have permission to view it from apache:
Do something for Zoneminder be better:
mcedit /usr/local/bin/zmdc.pl
Add following lines (marked with a '+'-sign between the lines given (do not include '+').
foreach my $arg ( @ARGV )
+# Create the directory first if it doesn't exist
+mkdir(ZM_PATH_SOCKS);
socket( CLIENT, PF_UNIX, SOCK_STREAM, 0 ) or Fatal( "Can't open socket: $!" );
my $saddr = sockaddr_un( SOCK_FILE );
Click F2 to save, click F10 to quit.
To be sure, add rights to the /tmp/zm directory
chown apache:apache -R /tmp/zm
Do something with php:
mcedit /etc/php.ini
change from:
;date.timezone =
to:
date.timezone = Asia/Ho_Chi_Minh
And change from:
short_open_tag = Off
to:
short_open_tag = On
Reboot box:
reboot
Tick the box for support for the Cambozola addon within your ZoneMinder installation: http://ip-address/zm (Options->Images tab->OPT_CAMBOZOLA)
If you want better quality video, cut -r 25 in Option->Images->FFMPEG_OUTPUT_OPTIONS ad replace with:
-f mp4 -r 25 -b 2048k -vcodec mpeg4
To check libjpeg-turbo works:
lsof |grep libjpeg.so.62.0.0
If it works quote like this:
[root@dvr ~]# lsof |grep libjpeg.so.62.0.0
httpd 1672 root mem REG 8,1 258704 6160404 /opt/libjpeg-turbo/lib64/libjpeg.so.62.0.0
httpd 1850 apache mem REG 8,1 258704 6160404 /opt/libjpeg-turbo/lib64/libjpeg.so.62.0.0
httpd 1851 apache mem REG 8,1 258704 6160404 /opt/libjpeg-turbo/lib64/libjpeg.so.62.0.0
httpd 1852 apache mem REG 8,1 258704 6160404 /opt/libjpeg-turbo/lib64/libjpeg.so.62.0.0
httpd 1853 apache mem REG 8,1 258704 6160404 /opt/libjpeg-turbo/lib64/libjpeg.so.62.0.0
httpd 1854 apache mem REG 8,1 258704 6160404 /opt/libjpeg-turbo/lib64/libjpeg.so.62.0.0
httpd 1855 apache mem REG 8,1 258704 6160404 /opt/libjpeg-turbo/lib64/libjpeg.so.62.0.0
httpd 1856 apache mem REG 8,1 258704 6160404 /opt/libjpeg-turbo/lib64/libjpeg.so.62.0.0
httpd 1857 apache mem REG 8,1 258704 6160404 /opt/libjpeg-turbo/lib64/libjpeg.so.62.0.0
zmc 1888 apache mem REG 8,1 258704 6160404 /opt/libjpeg-turbo/lib64/libjpeg.so.62.0.0
zma 1899 apache mem REG 8,1 258704 6160404 /opt/libjpeg-turbo/lib64/libjpeg.so.62.0.0
zmc 1960 apache mem REG 8,1 258704 6160404 /opt/libjpeg-turbo/lib64/libjpeg.so.62.0.0
zma 1971 apache mem REG 8,1 258704 6160404 /opt/libjpeg-turbo/lib64/libjpeg.so.62.0.0
zmc 1996 apache mem REG 8,1 258704 6160404 /opt/libjpeg-turbo/lib64/libjpeg.so.62.0.0
zma 2007 apache mem REG 8,1 258704 6160404 /opt/libjpeg-turbo/lib64/libjpeg.so.62.0.0
zmc 2032 apache mem REG 8,1 258704 6160404 /opt/libjpeg-turbo/lib64/libjpeg.so.62.0.0
zma 2043 apache mem REG 8,1 258704 6160404 /opt/libjpeg-turbo/lib64/libjpeg.so.62.0.0
zmc 2070 apache mem REG 8,1 258704 6160404 /opt/libjpeg-turbo/lib64/libjpeg.so.62.0.0
zma 2081 apache mem REG 8,1 258704 6160404 /opt/libjpeg-turbo/lib64/libjpeg.so.62.0.0
zmc 2106 apache mem REG 8,1 258704 6160404 /opt/libjpeg-turbo/lib64/libjpeg.so.62.0.0
zma 2117 apache mem REG 8,1 258704 6160404 /opt/libjpeg-turbo/lib64/libjpeg.so.62.0.0
zmc 2142 apache mem REG 8,1 258704 6160404 /opt/libjpeg-turbo/lib64/libjpeg.so.62.0.0
zma 2153 apache mem REG 8,1 258704 6160404 /opt/libjpeg-turbo/lib64/libjpeg.so.62.0.0
zmc 2178 apache mem REG 8,1 258704 6160404 /opt/libjpeg-turbo/lib64/libjpeg.so.62.0.0
zma 2189 apache mem REG 8,1 258704 6160404 /opt/libjpeg-turbo/lib64/libjpeg.so.62.0.0
Have fun.
Re: Centos 6.0 64-bit with ZM 1.25.0, FFmpeg, libjpeg-turbo,
Posted: Wed Dec 28, 2011 12:54 pm
by leyton01
Great walkthrough - I am going to try this with CentOS 6.2 and hopefully there will be not too many walls for a ZM/*nix noob.
Would you also recommend webmin for someone who knows very little about anything but windows? :)
Posted: Wed Jan 25, 2012 12:09 pm
by caseystone
Wow! Thanks for the great how-to (assuming it works! :-)
I may try this, since my script-kiddie Ubuntu 10.04 doesn't manage to keep running more than about two months without running into a dead OS situation (unless I have a bad hard disk).
Posted: Mon Jan 30, 2012 3:50 pm
by johnh48726
Good day,
This post caught my interest as I have been struggling installing ZM-1.25.0 on Centos6.2, 64bit, on a new platform for the entire weekend. I was successful in getting it installed and operational on a much smaller platform but not this.
Specifically I am getting a compile time error and, I am afraid, it is way beyond my abilities of debugging at this point. Any help greatly appreciated.
Here is the error after 'make'.
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include -D__STDC_CONSTANT_MACROS -g -O3 -march=native -mtune=native -MT zm_ffmpeg_camera.o -MD -MP -MF .deps/zm_ffmpeg_camera.Tpo -c -o zm_ffmpeg_camera.o zm_ffmpeg_camera.cpp
zm_ffmpeg_camera.cpp: In destructor âvirtual FfmpegCamera::~FfmpegCamera()â:
zm_ffmpeg_camera.cpp:62: warning: void av_close_input_file(AVFormatContext*) is deprecated (declared at /usr/local/include/libavformat/avformat.h:1402)
zm_ffmpeg_camera.cpp: In member function virtual int FfmpegCamera::PrimeCapture():
zm_ffmpeg_camera.cpp:95: error: av_open_input_file was not declared in this scope
zm_ffmpeg_camera.cpp:99: warning: int av_find_stream_info(AVFormatContext*) is deprecated (declared at /usr/local/include/libavformat/avformat.h:1232)
zm_ffmpeg_camera.cpp:126: warning: int avcodec_open(AVCodecContext*, AVCodec*) is deprecated (declared at /usr/local/include/libavcodec/avcodec.h:3678)
make[2]: *** [zm_ffmpeg_camera.o] Error 1
make[2]: Leaving directory `/root/ZoneMinder-1.25.0/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/root/ZoneMinder-1.25.0'
make: *** [all] Error 2
