I'm using ZM 1.24.2 on ubuntu 10.10. Configuring FOSCAM8908 with P/T. I cannot see the "control" tab in the monitor configuration. The tabs that are visible are , General, Source, Timestamp, Buffers & misc. The control tab is missing.
kindly help.
No Control tab in the monitor window
Re: No Control tab in the monitor window
Check if you have enabled the OPT_CONTROL in the OPTIONS:SYSTEM configuration values.
thanks it worked with OPT_control in the options.
