Page 1 of 1
GPU Decoding?
Posted: Wed Dec 21, 2011 10:28 pm
by rphenix
Is it possible to lessen the load on the CPU by using a GPU at all with zoneminder? So many of the GPU's claim things like native h.264 hardware accelerated decoding.
Re: GPU Decoding?
Posted: Fri Dec 23, 2011 4:02 pm
by humbytheory
I think that depends on the developers of ffmpeg since that is what ZoneMinder uses to generate the videos... After reading these two posts: http://forums.whirlpool.net.au/archive/1612969 and http://ffmpeg-users.933282.n4.nabble.co ... 14723.html it does not look good.
Re: GPU Decoding?
Posted: Sat Dec 24, 2011 2:48 am
by bb99
Re: GPU Decoding?
Posted: Sat Dec 24, 2011 3:59 pm
by humbytheory
I think that patch does look to improve the CPU performance, just not by using the GPU as rphenix was asking.. You know... this is why open source software rocks anyone can find an itch to scratch and mastertheknife's patch looks good I'm going to have to give it a try. Thanks for pointing out the patch!
