- Camera Specs:
-IMAGE SENSOR : 1/4" CMOS 1M PIXEL(COLOR)
-VIDEO COMPRESSION: MPEG-4/H.264
-VIDEO RESOLUTION:1280X720(30FPS)
-VIDEO COMPRESSION BIT RATE: 500KBIT/S -3MBIT/S
-PROTOCOL: TCP/UDP/IP/HTTP/FTP/SMTP/DHCP/DNS/ARP/ICMP/POP3/NTP
-COMMUNICATION INTERFACE: RJ45, 100M SELF-ADAPTIVE ETHERNET INTERFACE
-O/S: LINUX (MontaVista Linux Professional Edition 4.0.1 )
I can telnet into the cameras and get a shell, when I run a netstat -l I get the following:
- MontaVista(R) Linux(R) Professional Edition 4.0.1 (0502020)
Linux/armv5tejl 2.6.10_mvl401_IPNC-1.0.6
/ $ netstat -l
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State
tcp 0 0 *:8000 *:* LISTEN
tcp 0 0 *:login *:* LISTEN
tcp 0 0 *:shell *:* LISTEN
tcp 0 0 *:9000 *:* LISTEN
tcp 0 0 *:9001 *:* LISTEN
tcp 0 0 *:ftp *:* LISTEN
tcp 0 0 *:telnet *:* LISTEN
tcp 0 0 *:9050 *:* LISTEN
udp 0 0 *:9093 *:*
Active UNIX domain sockets (only servers)
Proto RefCnt Flags Type State I-Node Path
