pathetic_programmer wrote:If I'm not mistaken, Zoneminder keeps everything in RAM until it needs to write it to disk. That is probably the reason why you have to increase the amount of shared RAM available in the kernel when you have a large amount of cameras or high frame rate systems. What's probably happening is that you either don't have enough RAM in your system, or your getting a large amount of alerts that have to be written.
Sound good thats it's the default settings, but can i verify somehow that it actually does use the RAM for the temp files?
pathenic_programmer wrote:If you don't have enough RAM to handle all of your high frame rate cameras, then your computer may be automatically start swapping out data to your hard drive to have room for other things to be processed. In order to help alleviate this, you could lower the buffers or add more RAM to your system.
The machine has 1 gig of ram, and its running ubuntu server 11.04 (which takes only about 2-300 MB RAM on its own, so the rest is for zoneminder only.
I will take a look into that, sound great!!
steffan wrote:is this possible? i think it will help alot on my performance, which would be great since zoneminder is
not the only server running on those disks in my setup
That right there might be your problem too. I'm not saying that Zoneminder isn't friendly with other programs, but they may be what is causing all the traffic to the disks.
Oh, i think you misunderstod me..
Quick overview of my setup:
I run my zoneminder server in a VMware ESX server, as a virtual machine, this ESX server runs miltiple virtual machines, both windows and linux, all those virtual machines run off the same NFS storage which is a RAID5 disk array. performance on these disk's are great, right now im running 7 virtual server, and i can still write to the disk's with 10 MB/s without them overloading at all.
But as soon as i start my zoneminder server (which only runs zoneminder on that OS, and no other application/services) the disk array get overloadet easely, so zoneminder must take a LOT of the disk's speed.
I have disabled all camera's in my zoneminder setup, so i only have 1 active, that one is an AXIS with 640x480, with an ALARM FPS of 30, and a "standby" (when there are no alarms) FPS of 10. and set so if an alarm accours, 40 frames before the alarm will get saved too.
(feel free to ask for screenshots or whatever you need of my zoneminder settings!)
Try this, in a command line, type in:
This will show you how much of your Swap space, (Virtual RAM) is in use. If it is full then your system may not have enough RAM to handle Zoneminder and the other programs running on that system.
here's the output:
zm@zm:~$ free -m
total used free shared buffers cached
Mem: 1001 389 611 0 25 227
-/+ buffers/cache: 135 865
Swap: 1101 0 1101
In my eyes, thats looks good. no swap used, over 600 megs of free physical RAM
And thanks for your answer, im really lost on this one, i somehow think i just made some settings wrong..
