How to use ramdisk?
Posted: Sun Dec 25, 2011 2:30 pm
Hey Guys,
Iv'e noticed that my zoneminder installation is using a lot of the disk's speed since im going for high FPS,
The way i have understand that zoneminder works is by taking a picture from the camera, then takes another picture and then compares them, if there's any change, then start recording. if not, it deletes the pictures that it used for checking after the specified number of "Buffer pictures" .. right ??? or am i wrong?
Anyways, my idear was to use a RAMdisk for all those temperary pictures that zoneminder uses for checking, but where can i specify do use another folder for this ? looks like it default uses the "events" folder, where it also saves the recordet alarms.
is this possible? i think it will help alot on my performance, which would be great since zoneminder is not the only server running on those disks in my setup
-Steffan
-Steffan
