Good day all.
Could someone please advice me how I can go about exporting event videos without losing quality.
I ask as each time I try and export an event to a video, the quality of the exported video is very bad.
Can you please advice.
Thanks for your time.
Best Regards.
exporting event video without losing quality
Re: exporting event video without losing quality
I do my cams at 640 x 480 and I have exported with every format option, and I hear ya with the poor quality playing the file outside of the ZM console. I think editing the FFMPEG_OUTPUT_OPTIONS would be where I would start.
Add -qscale 5 to ffmpeg output parameters, this should give you about 80-90% quality.
mastertheknife
mastertheknife
Kfir Itzhak.
Are you saying replace the -r 25 with -qscale 5 in the options menu or do I have to nano it ?
WOW works like a charm, Thank you !
That is so much better now, thank you.
