Page 1 of 1
Problems compiling ZoneMinder 1.25.0 on 32bit LinuxMint 12
Posted: Mon Jan 30, 2012 12:42 pm
by georgedone
When I try the configure I get the following warnings:
./configure --with-webdir=/var/www/html/zm --with-cgidir=/var/www/cgi-bin ZM_DB_PASS=<my_password>
checking for mysql/mysql.h... yes
checking libavutil/avutil.h usability... no
checking libavutil/avutil.h presence... yes
configure: WARNING: libavutil/avutil.h: present but cannot be compiled
configure: WARNING: libavutil/avutil.h: check for missing prerequisite headers?
configure: WARNING: libavutil/avutil.h: see the Autoconf documentation
configure: WARNING: libavutil/avutil.h: section "Present But Cannot Be Compiled"
configure: WARNING: libavutil/avutil.h: proceeding with the compiler's result
configure: WARNING: ## ------------------------------------------------------------------------- ##
configure: WARNING: ## Report this to http://www.zoneminder.com/forums/ - Please check FAQ first ##
checking for libavutil/avutil.h... no
checking libavcodec/avcodec.h usability... no
checking libavcodec/avcodec.h presence... yes
configure: WARNING: libavcodec/avcodec.h: present but cannot be compiled
configure: WARNING: libavcodec/avcodec.h: check for missing prerequisite headers?
configure: WARNING: libavcodec/avcodec.h: see the Autoconf documentation
configure: WARNING: libavcodec/avcodec.h: section "Present But Cannot Be Compiled"
configure: WARNING: libavcodec/avcodec.h: proceeding with the compiler's result
checking for libavcodec/avcodec.h... no
checking libavformat/avformat.h usability... no
checking libavformat/avformat.h presence... yes
configure: WARNING: libavformat/avformat.h: present but cannot be compiled
configure: WARNING: libavformat/avformat.h: check for missing prerequisite headers?
configure: WARNING: libavformat/avformat.h: see the Autoconf documentation
configure: WARNING: libavformat/avformat.h: section "Present But Cannot Be Compiled"
configure: WARNING: libavformat/avformat.h: proceeding with the compiler's result
checking for libavformat/avformat.h... no
checking libswscale/swscale.h usability... no
checking libswscale/swscale.h presence... no
checking for libswscale/swscale.h... no
checking pcre/pcre.h usability... no
checking pcre/pcre.h presence... no
checking for pcre/pcre.h... no
checking pcre.h usability... yes
checking pcre.h presence... yes
Not surprisingly, make have truble compiling that section:
mint12 ZoneMinder-1.25.0 # make
make all-recursive
make[1]: Entering directory `/home/george/Downloads/ZoneMinder-1.25.0'
Making all in src
make[2]: Entering directory `/home/george/Downloads/ZoneMinder-1.25.0/src'
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include -g -O2 -MT zmc.o -MD -MP -MF .deps/zmc.Tpo -c -o zmc.o zmc.cpp
In file included from zm_stream.h:27:0,
from zm_event.h:39,
from zm_zone.h:27,
from zm_monitor.h:26,
from zmc.cpp:28:
zm_mpeg.h:43:7: error: use of enum ‘PixelFormat’ without previous declaration
zm_mpeg.h:44:2: error: ‘AVOutputFormat’ does not name a type
zm_mpeg.h:45:2: error: ‘AVFormatContext’ does not name a type
zm_mpeg.h:46:2: error: ‘AVStream’ does not name a type
zm_mpeg.h:47:2: error: ‘AVFrame’ does not name a type
zm_mpeg.h:48:2: error: ‘AVFrame’ does not name a type
make[2]: *** [zmc.o] Error 1
make[2]: Leaving directory `/home/george/Downloads/ZoneMinder-1.25.0/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/george/Downloads/ZoneMinder-1.25.0'
make: *** [all] Error 2
before running ./configure I've installed via Synaptic:
libavutil-dev 4:0.7.3 (latest)
libavcodec-dev 4:0.7.3 (latest)
libavformat-dev 4:0.7.3
Anyone run into this problem ?
Re: Problems compiling ZoneMinder 1.25.0 on 32bit LinuxMint
Posted: Mon Jan 30, 2012 1:39 pm
by mastertheknife
Add CPPFLAGS="${CFLAGS} -D__STDC_CONSTANT_MACROS" to your ./configure
mastertheknife
Posted: Mon Jan 30, 2012 4:28 pm
by georgedone
Thank you, Ytzhak
You advice was right to the point, after implementing it I get no more relevant warnings when I run ./configure.
However, it still throws errors (in a later stage) during make. It is related to ffmpeg (which I've instaled precompiled from ubuntu repositories (latest version)).
I guess I have to look into it, check the forums to see what is the compatible version and maybe get it from videolan and compile it. Oh well...
Thank you again for quickly helping me get over the first error.
"mv -f .deps/zm_file_camera.Tpo .deps/zm_file_camera.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include -march=native -O2 -pipe -D__STDC_CONSTANT_MACROS -march=native -O2 -pipe -MT zm_ffmpeg_camera.o -MD -MP -MF .deps/zm_ffmpeg_camera.Tpo -c -o zm_ffmpeg_camera.o zm_ffmpeg_camera.cpp
zm_ffmpeg_camera.cpp: In destructor ‘virtual FfmpegCamera::~FfmpegCamera()’:
zm_ffmpeg_camera.cpp:51:42: error: ‘sws_freeContext’ was not declared in this scope
zm_ffmpeg_camera.cpp: In member function ‘virtual int FfmpegCamera::PrimeCapture()’:
zm_ffmpeg_camera.cpp:94:10: warning: ‘int av_open_input_file(AVFormatContext**, const char*, AVInputFormat*, int, AVFormatParameters*)’ is deprecated (declared at /usr/include/libavformat/avformat.h:1050) [-Wdeprecated-declarations]
zm_ffmpeg_camera.cpp:94:76: warning: ‘int av_open_input_file(AVFormatContext**, const char*, AVInputFormat*, int, AVFormatParameters*)’ is deprecated (declared at /usr/include/libavformat/avformat.h:1050) [-Wdeprecated-declarations]
zm_ffmpeg_camera.cpp:125:10: warning: ‘int avcodec_open(AVCodecContext*, AVCodec*)’ is deprecated (declared at /usr/include/libavcodec/avcodec.h:3650) [-Wdeprecated-declarations]
zm_ffmpeg_camera.cpp:125:46: warning: ‘int avcodec_open(AVCodecContext*, AVCodec*)’ is deprecated (declared at /usr/include/libavcodec/avcodec.h:3650) [-Wdeprecated-declarations]
make[2]: *** [zm_ffmpeg_camera.o] Error 1
make: *** [all] Error 2"
Posted: Thu Feb 02, 2012 2:25 am
by Mattt
georgedone wrote:Thank you, Ytzhak
I seem to be stuck here now, also :-(
Cheers,
Mattt.
Posted: Thu Feb 02, 2012 9:39 am
by mastertheknife
Need to install libswscale-dev or the equivalent package for your distro.
mastertheknife
Posted: Thu Feb 02, 2012 9:44 am
by Mattt
Nope - got that already...
Cheers,
Mattt.
Posted: Thu Feb 02, 2012 9:57 am
by Mattt
I'm on Ubuntu 11.10, btw... Trying to build current SVN as well as most recent stable tarball. Have tried both versions with both current GIT ffmpeg and also Ubuntu repo version. Every combination yields the same results.
Cheers,
Mattt.
Posted: Fri Feb 03, 2012 12:09 pm
by georgedone
@mastertheknife
In my case installing libswscale-dev solved the problem and make ran succesfully, thank you.
I still have some problems during make install
test -z "/var/www/html/zm/views" || /bin/mkdir -p "/var/www/html/zm/views"
/usr/bin/install -c -m 644 file.php image.php '/var/www/html/zm/views'
make[3]: Leaving directory `/home/george/Downloads/ZoneMinder-1.25.0/web/views'
make[2]: Leaving directory `/home/george/Downloads/ZoneMinder-1.25.0/web/views'
make[2]: Entering directory `/home/george/Downloads/ZoneMinder-1.25.0/web'
make[3]: Entering directory `/home/george/Downloads/ZoneMinder-1.25.0/web'
make[3]: Nothing to be done for `install-exec-am'.
test -z "/var/www/html/zm" || /bin/mkdir -p "/var/www/html/zm"
/usr/bin/install -c -m 644 index.php '/var/www/html/zm'
make install-data-hook
make[4]: Entering directory `/home/george/Downloads/ZoneMinder-1.25.0/web'
( cd /var/www/html/zm; chown apache:apache index.php )
chown: invalid user: `apache:apache'
make[4]: *** [install-data-hook] Error 1
make[4]: Leaving directory `/home/george/Downloads/ZoneMinder-1.25.0/web'
make[3]: *** [install-data-am] Error 2
make[3]: Leaving directory `/home/george/Downloads/ZoneMinder-1.25.0/web'
make[2]: *** [install-am] Error 2
make[2]: Leaving directory `/home/george/Downloads/ZoneMinder-1.25.0/web'
make[1]: *** [install-recursive] Error 1
make[1]: Leaving directory `/home/george/Downloads/ZoneMinder-1.25.0/web'
make: *** [install-recursive] Error 1
But those must have something to do with the way I had initially apache setup (I was running precompilled version of zoneminder 1.24-4 from ubuntu depot (which also pulled and installed apache2 as a prerequisite before the compilation of 1.25.0 version)
I will create the apache:apache user tough I have to read if it needs a shell to function properly for zoneminder (probably not).
Posted: Fri Feb 03, 2012 12:34 pm
by Mattt
Sadly, I'm still unable to build. I forgot to mention that I'm running 64 bit. Does that make any difference?
Cheers,
Mattt.
Posted: Sat Feb 04, 2012 12:13 am
by mastertheknife
georgedone wrote:@mastertheknife
Hi George,
Please use www-data for web user and group instead of apache for your distro.
--with-webuser=www-data --with-webgroup=www-data
mastertheknife
Posted: Sun Feb 12, 2012 6:18 pm
by barneyward
I have the same problem...
I followed these instructions for installing up-to-date ffmpeg and x264 from source,
http://ubuntuforums.org/showthread.php?t=786095
Downloaded ZoneMinder version 1.25.0 and configured with:
./configure --with-ffmpeg=/home/barney --with-webdir=/var/www/barneyward/zm --with-cgidir=/var/www/barneyward/zm/cgi-bin --with-webuser=www-data --with-webgroup=www-data --enable-mmap=no CPPFLAGS="${CFLAGS} -D__STDC_CONSTANT_MACROS"
and got exactly the same problem:
g++ -DHAVE_CONFIG_H -I. -I..  -I/usr/include -I/home/barney/include -Wall -Wno-sign-compare -fno-inline -I/home/barney/include  -D__STDC_CONSTANT_MACROS  -g -O2 -MT zm_ffmpeg_camera.o -MD -MP -MF .deps/zm_ffmpeg_camera.Tpo -c -o zm_ffmpeg_camera.o zm_ffmpeg_camera.cpp
zm_ffmpeg_camera.cpp:61: warning: ‘void av_close_input_file(AVFormatContext*)’ is deprecated (declared at /usr/local/include/libavformat/avformat.h:1417)
zm_ffmpeg_camera.cpp:94: error: ‘av_open_input_file’ was not declared in this scope
zm_ffmpeg_camera.cpp:98: warning: ‘int av_find_stream_info(AVFormatContext*)’ is deprecated (declared at /usr/local/include/libavformat/avformat.h:1247)
zm_ffmpeg_camera.cpp:125: warning: ‘int avcodec_open(AVCodecContext*, AVCodec*)’ is deprecated (declared at /usr/local/include/libavcodec/avcodec.h:3661)
make[2]: Leaving directory `/home/barney/ZoneMinder-1.25.0/src'
make[1]: Leaving directory `/home/barney/ZoneMinder-1.25.0'
libswscale-dev is apparently the latest version!
Using ubuntu 10.04
Any help appreciated
