My Current ZoneMinder Server.
Tyan Thunder K8SD Pro S2882-D Motherboard.
2x Dual Core AMD Opteron 275 Processor (2.2Ghz).
4x 2GB DDR400 ECC Memory (8GB).
1x Seagate 500GB. (OS Drive).
1x WDC Green 1.5TB. (Spare).
2x WDC Green 2.0TB. (Raid-1, Zoneminder Events).
1x 4 Port Single Chip BT878.
Running Ubuntu 11.04 x64 Server, Zoneminder v1.24.2.
/etc/sysctl.conf
# Shared Memory For Zoneminder
kernel.shmmax = 4162813952
kernel.shmall = 2032624
Here is that post: Xvision X100V MegaPixel Indoor/Outdoor IP Camera
Right down to the problem.
I have entered the following into zoneminder, but get no video stream from the ip camera.
Source
Remote Protocol: RTSP
Remote Method: RTP/RTSP/HTTP
Remote Host Name: xxx.xxx.xxx.xxx
Remote Host Port: 554
Remote Host Path: /media/media.amp?videocodec=jpeg&resolution=640x480&audio=0
Capture Width (pixels): 640
Capture Height (pixels): 480
Preserve Aspect Ratio: Unticked
Orientation: Normal
Within zoneminder the Source turns Orange, if you refresh the page it then turns Red.
Reading the X100V RTSP manual
New RTSP URL format
H264
rtsp://xxx.xxx.xxx.xxx:554/media/media.amp?videocodec=h264&resolution=640x480&audio=0
MPEG4
rtsp://xxx.xxx.xxx.xxx:554/media/media.amp?videocodec=mpeg4&resolution=640x480&audio=0
MJPEG
rtsp://xxx.xxx.xxx.xxx:554/media/media.amp?videocodec=jpeg&resolution=640x480&audio=0
Old RTSP URL format
H264
rtsp://xxx.xxx.xxx.xxx:554/h264/media.amp?resolution=640x480
rtsp://xxx.xxx.xxx.xxx:554/h264/1/media.amp?resolution=640x480
MPEG4
rtsp://xxx.xxx.xxx.xxx:554/mpeg4/media.amp
rtsp://xxx.xxx.xxx.xxx:554/mpeg4/media.amp?resolution=640x480
rtsp://xxx.xxx.xxx.xxx:554/mpeg4/1/media.amp
rtsp://xxx.xxx.xxx.xxx:554/mpeg4/1/media.amp?resolution=640x480
MJPEG
rtsp://xxx.xxx.xxx.xxx:554/mjpg/video.mjpg?resolution=640x480
rtsp://xxx.xxx.xxx.xxx:554/mjpg/1/video.mjpg?resolution=640x480
3GPP
rtsp://xxx.xxx.xxx.xxx:554/mpeg4/media.3gp
Looking at the logs of the IP camera it's self, show the remote rtsp feed request and that the camera starts sending the video stream.
What logs do I have to look at on the zoneminder server?
Xvision does have two live demo camera's that can be viewed here: http://www.ipcctv.com/article.php?xArt=14
Can someone please advice what I should do to try and get this working.
Thanks for your time.
Best Regards.
