Generic camera....DCL Data Concept Limited $65
kmrs75
Post by kmrs75 »
I decided to pick up this generic camera for a project that I am on. I was able to get it to work with zoneminder. It works good.
Its not too bad at all. The price is great and its very small. the case is built well.
I have been doing some research and this company DCL seams to be the same manufacture of the foscam cameras
I updated the wiki with this camera.
JPEG
Remote Protocol: HTTP
Remote Method: Simple
Remote Host Name: username:password@<IP ADDRESS> default = admin:@192.168.1.126
Remote Host Port: 81 default port = 81
Remote Host Path: /image9ce9.jpg
pros and cons
little to no features
cant set a static IP address thru the camera. It has to be done in the router.
default port is 81 that cant be changed
no branding or manufacture
hard wire only
only works in 320x240
no reset button to manufacture setting (but there isnt much you can change anyway)
very clear night vision
very cheap about $65
very small
http://www.meritline.com/metal-casing-i ... 75866.aspx
http://www.zoneminder.com/wiki/index.php/Generic
