Here's a patch to fix the WML php for 1.19.1... fixed and cleaned it up a little. You'll have to apply it before doing your make install. (hopefully the forum won't ruin the patch file)
cut and paste into wml.patch
cd to your zm-1.19.1 directory
patch -p1 < wml.patch
make install
hit http://zm.yoursite.com/zm_wml.php and wha-la!
diff -Naur zm-1.19.1-orig/web/zm_wml.php zm-1.19.1/web/zm_wml.php
--- zm-1.19.1-orig/web/zm_wml.php 2004-02-15 14:10:59.000000000 -0500
+++ zm-1.19.1/web/zm_wml.php 2004-03-24 20:25:22.000000000 -0500
@@ -55,6 +55,17 @@
switch( $view )
+ case "function" :
+ case "events" :
+ print "<wml>\n";
+ print "<card id=\"zmFuncitons\" title=\"ZM $view\">\n";
+ print "<p mode=\"nowrap\" align=\"center\"><strong>ZM - $view</strong></p>\n";
+ print "<p mode=\"nowrap\" align=\"center\">Not supported yet. Sorry.</p>\n";
+ print "</card>\n";
+ print "</wml>\n";
+ break;
case "console" :
case "feed" :
diff -Naur zm-1.19.1-orig/web/zm_wml_view_console.php zm-1.19.1/web/zm_wml_view_console.php
--- zm-1.19.1-orig/web/zm_wml_view_console.php 2004-02-15 14:10:59.000000000 -0500
+++ zm-1.19.1/web/zm_wml_view_console.php 2004-03-24 20:25:34.000000000 -0500
@@ -22,7 +22,16 @@
$HTTP_SESSION_VARS['event_reset_time'] = "2000-01-01 00:00:00";
$db_now = strftime( "%Y-%m-%d %H:%M:%S" );
-$sql = "select M.*, count(E.Id) as EventCount, count(if(E.StartTime>'$HTTP_SESSION_VARS['event_reset_time']' && E.Archived = 0,1,NULL)) as ResetEventCount, count(if(E.StartTime>'$db_now' - INTERVAL 1 HOUR && E.Archived = 0,1,NULL)) as HourEventCount, count(if(E.StartTime>'$db_now' - INTERVAL 1 DAY && E.Archived = 0,1,NULL)) as DayEventCount from Monitors as M left join Events as E on E.MonitorId = M.Id group by M.Id order by M.Id";
+$sql = sprintf("SELECT M.*,
+ COUNT(E.Id) AS EventCount,
+ COUNT(if(E.StartTime>'%s' && E.Archived = 0,1,NULL)) AS ResetEventCount,
+ COUNT(if(E.StartTime>'%s' - INTERVAL 1 HOUR && E.Archived = 0,1,NULL)) AS HourEventCount,
+ COUNT(if(E.StartTime>'%s' - INTERVAL 1 DAY && E.Archived = 0,1,NULL)) AS DayEventCount
+ FROM Monitors AS M
+ LEFT JOIN Events AS E
+ ON E.MonitorId = M.Id
+ GROUP BY M.Id
+ ORDER BY M.Id", $HTTP_SESSION_VARS['event_reset_time'], $db_now, $db_now);
$result = mysql_query( $sql );
if ( !$result )
echo mysql_error();
@@ -34,7 +43,13 @@
if ( $max_width < $row['Width'] ) $max_width = $row['Width'];
if ( $max_height < $row['Height'] ) $max_height = $row['Height'];
- $sql = "select count(Id) as ZoneCount, count(if(Type='Active',1,NULL)) as ActZoneCount, count(if(Type='Inclusive',1,NULL)) as IncZoneCount, count(if(Type='Exclusive',1,NULL)) as ExcZoneCount, count(if(Type='Inactive',1,NULL)) as InactZoneCount from Zones where MonitorId = '$row['Id']'";
+ $sql = sprintf("SELECT COUNT(Id) AS ZoneCount,
+ COUNT(if(Type='Active',1,NULL)) AS ActZoneCount,
+ COUNT(if(Type='Inclusive',1,NULL)) AS IncZoneCount,
+ COUNT(if(Type='Exclusive',1,NULL)) AS ExcZoneCount,
+ COUNT(if(Type='Inactive',1,NULL)) AS InactZoneCount
+ FROM Zones
+ WHERE MonitorId = '%s'",$row['Id']);
$result2 = mysql_query( $sql );
if ( !$result2 )
echo mysql_error();
@@ -51,12 +66,12 @@
while( $row = mysql_fetch_assoc( $result ) )
- $ps_array = preg_split( "/\s+/", exec( "ps -edalf | grep 'zmc $row['Device']' | grep -v grep" ) );
+ $ps_array = preg_split( "/\s+/", exec( "ps -edalf | grep 'zmc " . $row['Device'] . "' | grep -v grep" ) );
if ( $ps_array[3] )
$row['zmc'] = 1;
- $ps_array = preg_split( "/\s+/", exec( "ps -edalf | grep 'zma $row['Device']' | grep -v grep" ) );
+ $ps_array = preg_split( "/\s+/", exec( "ps -edalf | grep 'zma " . $row['Device'] . "' | grep -v grep" ) );
if ( $ps_array[3] )
$row['zma'] = 1;
diff -Naur zm-1.19.1-orig/web/zm_wml_view_feed.php zm-1.19.1/web/zm_wml_view_feed.php
--- zm-1.19.1-orig/web/zm_wml_view_feed.php 2004-02-15 14:10:59.000000000 -0500
+++ zm-1.19.1/web/zm_wml_view_feed.php 2004-03-24 20:25:34.000000000 -0500
@@ -18,7 +18,7 @@
// Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-$result = mysql_query( "select * from Monitors where Id = '$mid'" );
+$result = mysql_query( "SELECT * FROM Monitors WHERE Id = '$mid'" );
if ( !$result )
die( mysql_error() );
$monitor = mysql_fetch_assoc( $result );
Fix for WML PHP
Re: Fix for WML PHP
oh well, didn't post well... just go download it here: http://www.linuxninja.net/stuff/zm-1.19.1-wml.patch
- zoneminder
- Site Admin
- Contact:
Re: Fix for WML PHP
Hi Karl,
Thanks for that. Revamping the WML and mobile support has been near the top of my 'to-do' list for the last few months but tends to get bounced by more urgent requests. I did spend a while yesterday experimenting with an email to MMS gateway and getting alarm images sent to my phone that way as well. It worked pretty well really and I'll try and add some useful things to support that as well, when I get around to it.
Cheers,
Phil,
Cheers,
Phil,
