Hi all,
My system is an 10.04.4 ubuntu server 32 bits LTS. My zoneminder is a 1.25. installed from source.
My camera is a vivotek ip7330 which is working in rtsp and http by vlc or others players.
In zoneminder 1.25, I can see in JPEG and rtsp from the MPeg4 camera stream.
If I use MJPEG, I can see a blank screen in the console view (my sharememory is ok).
Is RTSP working in zoneminder 1.25, if yes what we have to do ?
pb with console : rtsp + MJPEG and all uptodate
Re: pb with console : rtsp + MJPEG and all uptodate
Have you tried the ffmpeg mode?
mastertheknife
mastertheknife
Kfir Itzhak.
No I don't use FFMPEG mode.
Where I can find instructions.
I will try.
Thank you.
edit: I configure the ffmpeg mode and same thing when I select mjpeg, no image. If I select jpeg , it works. So the result is the same as rtsp mode.
Zonminder don't like mjpeg with rtsp.
I will try.
Thank you.
This should help (not exact camera, but notice the "Source Type" and the "Source Path"gilles wrote:Hi,
I will try.
Thank you.
General
Source Type: Ffmpeg
Function: Modect
Enabled: yes
Linked Monitors: N/A
Maximum FPS: 8.00
Alarm Maximum FPS: 15.00
Reference Image Blend %ge: 7
Triggers: None
Source
Source Path: rtsp://<username>:<password>@<ip address or dns>/axis-media/media.amp?tcp
Source Colours: 24 bit colour
Capture Width (pixels): 1280
Capture Height (pixels): 720
Preserve Aspect Ratio: no
Orientation: Normal
This is from my Axis P5534 PTZ.
