Strange /dev/video permission errors
johngc
Post by johngc »
I have ZM 1.25.0 installed on Ubuntu 10.04 x64 server edition and it has been working perfectly. I use a generic BT878 capture card which had two cameras plugged into it. As the frame rate was low I got hold of a second BT878 generic capture card and again it just seemed to plug and play :lol:
BUT, recently I have started to notice the feed on my new card crashing. The only error I can see in the log file is:
Failed to open video device /dev/video1: Permission denied
If I ls -l /dev/video* I can see:
crw-rw-rw-+ 1 root video 81, 0 2012-03-01 06:15 /dev/video0
crw-rw-rw-+ 1 root video 81, 2 2012-03-01 06:15 /dev/video1
So I know the permissions are set the same.
Resetting ZM works fine and it runs as normal until next time I notice it crash!
Any suggestions on how I can start to troubleshoot this would be greatly received.
mastertheknife
Re: Strange /dev/video permission errors
Post by mastertheknife »
Add www-data to the video group.
e.g.
gpasswd -a www-data video
mastertheknife
Kfir Itzhak.
johngc
Post by johngc »
Thank you - I will try that.
Since my post and today I have not had a problem with it in any case. There have been a number of alerts on the camera so I know it is working. I will keep an eye on it and see how it goes.
Thanks again
