Page 1 of 1
Zoneminder and other DVR output
Posted: Sun Mar 04, 2012 11:42 pm
by fjenou
Hi all, greetings,
Not sure if this is the right forum to post; I Googled a lot but found no answer for this question:
I have a 4 channel DVR which is viewable on Internet with Android MEYE app. Can I capture this video stream by a remote Zoneminder installation? If possible, how?
Thanks.
Re: Zoneminder and other DVR output
Posted: Mon Mar 05, 2012 2:59 pm
by nightcrawler
General is possible to use this. Zoneminder can capture from MPJEG streams. so if you know an direct URL to one of your cam's streams you can use this on the "add monitor" page. It's the same way that an IP camera works. see the ZM wiki at >
http://www.zoneminder.com/wiki/index.ph ... Digitizers
But you have to be sure that's an direct URL like this example from the foscam page of the wiki:
http://YOURURL.COM/videostream.cgi?user=admin&pwd=12345&resolution=32&rate=6
Zoneminder can't handle java or flash applets that stream video. only direct inputs.
Posted: Wed Mar 07, 2012 8:30 pm
by fjenou
Hi nightcrawler,
Thanks for your suggestion.
I used tcpdump to tap into Android MEYE and DRV traffic, but no joy, nothing identifiable as a http string.
Googled some more and arrived at this frustrating conclusion: the protocol that governs MEYE and DRV remote viewing must be the best-protected industry secret...
Before anyone asks, yes, Zoneminder installation is working (with 3 Foscam IP cameras).
Regards,
Posted: Fri Mar 16, 2012 10:52 pm
by humbytheory
Hey fjenou, what's the DVR you're using?
Posted: Sat Mar 17, 2012 7:38 pm
by fjenou
Hi humbytheory, it´s a generic Linux-based 4channel DVR made by a Brazilian company, Tecvoz TEC-SA04.
