Private areas hiding
expotel
Post by expotel »
Is it possible with Zoneminder, hide private areas?
Sergio Bruni
nightcrawler
Re: Private areas hiding
Post by nightcrawler »
no it isn't
Zoneminder @Ubuntu 11 server, ZM 1.25.0 , FFMPEG, 4 Analoge cameras, 1.6ghz P4mobile, 2GB ram, 60GB-HDD.
I also have an (homeseer) domotica system up-and-running with touchscreens,light controllers,weather forecast etc.
AllenTuttle
Post by AllenTuttle »
It depends on what you mean by "Private areas hiding".
For instance if you have 4 cameras and 1 should be private, this is easy to accomplish by enabling user login and restricting the camera.
If you mean block part of an image from a specific camera, that is done in some of my cameras (mostly Axis) by uploading a 'mask' to the camera. ZoneMinder isn't used to accomplish this.
bb99
Post by bb99 »
I'm using a small piece of 1/4" plywood, another local user is using tape on the glass lens endcap. Noticed a post where cardboard was used to block out a light that otherwise would've washed the entire picture out. I should add: if you just don't want to trigger recording in that area check out inactive zones in the doc.
