Page 1 of 1
Private areas hiding
Posted: Tue Mar 06, 2012 11:01 am
by expotel
Is it possible with Zoneminder, hide private areas?
Sergio Bruni
Re: Private areas hiding
Posted: Tue Mar 06, 2012 1:46 pm
by nightcrawler
no it isn't
Posted: Mon Apr 16, 2012 7:42 pm
by AllenTuttle
It depends on what you mean by "Private areas hiding".
For instance if you have 4 cameras and 1 should be private, this is easy to accomplish by enabling user login and restricting the camera.
If you mean block part of an image from a specific camera, that is done in some of my cameras (mostly Axis) by uploading a 'mask' to the camera. ZoneMinder isn't used to accomplish this.
Posted: Tue Apr 17, 2012 3:05 am
by bb99
I'm using a small piece of 1/4" plywood, another local user is using tape on the glass lens endcap. Noticed a post where cardboard was used to block out a light that otherwise would've washed the entire picture out. I should add: if you just don't want to trigger recording in that area check out inactive zones in the doc.
