luminance varies itself.. causes event
Posted: Thu Mar 08, 2012 8:00 am
Hi to Everybody.
I built surveillance system using centos 6 and zoneminder 1.24.4. My goal was to integrate it with mythtv dvr-system.
I have four composite cameras connected to pico card. Everything works fine, except I am getting lots of false alarms caused by brightness changes.
I don't know what happens, but I see brightness changes in picture, and it happens in all cameras at same time. I think pico card somehow "adjusts" brightness, but how?
Brightness changes looks just like if there is some kind of sensor and automatic gain control. First I thought that cameras do it, but it really happens in all cameras at same time. And then I have four events recorded at same second..
I have tried to define max alarm pixels in zones, but it still triggers alarm. I also have tried bttv options in modprobe/bttv.conf.
I think there is two options that could affect:
chroma_agc 444 0-1 0 (No) Enables the AGC of chroma signal
adc_crush 444 0-1 1 (Yes) Enables the luminance ADC crush
I tried disable both, but did not see any changes.
Is my card bad? It is cheap ebay card, so I don't expect much from it.
