I tried to change the events path without success.
In options I left 'Events'
and in the original folder of Events I created a sym link with ln command to new path on another hard drive.
But the events aren't recorded and IP camera's address in list are in orange colour. Why?
Thanks.
How to change Events path
Re: How to change Events path
mount external drive to store events:
mkdir /zmdisk
mount /dev/sdc1 /zmdisk
mkdir /zmdisk/events /zmdisk/images /zmdisk/temp
rm -rf /usr/share/zoneminder/events
rm -rf /usr/share/zoneminder/images
rm -rf /usr/share/zoneminder/temp
ln -s /zmdisk/events /usr/share/zoneminder/events
ln -s /zmdisk/images /usr/share/zoneminder/images
ln -s /zmdisk/temp /usr/share/zoneminder/temp
Be careful in the rm -rf steps, if you already have events, images, etc, first copy the complete directories to the new hard drive.
Hope it helps,
PacoLM
mkdir /zmdisk
Hope it helps,
PacoLM
FYI: You haven't mentioned your distro. For Ubuntu, locations are different, and I struggled a long time until I came upon someone else's post about using FSTAB. For an odd Ubuntu reason, symlinks weren't working properly and I had to use FSTAB to make it all work out. From the link:
fstab could allow you to bind-mount an alternate location:
/dev/sdX1 /otherdrive ext3 defaults 0 2 /otherdrive/zoneminder/images /var/cache/zoneminder/images none defaults,bind 0 2 /otherdrive/zoneminder/events /var/cache/zoneminder/events none defaults,bind 0 2
or in some cases,
/otherdrive/zoneminder/images /usr/share/zoneminder/images none defaults,bind 0 2 /otherdrive/zoneminder/events /usr/share/zoneminder/events none defaults,bind 0 2
/dev/sdX1 /var/cache/zoneminder/images ext3 defaults 0 2 /dev/sdX2 /var/cache/zoneminder/events ext3 defaults 0 2
or in some cases,
