Zoneminder no streaming images for web interface
Posted: Tue Mar 13, 2012 10:20 pm
Hi everybody. I had a Debian Squeeze 64 bits + Zoneminder box with 8 cameras working for many months without errors. My DVR card is a Pico2000 chipset 16 Channels. Today when open a window for streaming theres no image in any one camera.
First I check logs. This is what i found
This error appears many times:
Mar 13 08:15:56 zm web_php[18340]: ERR [socket_sendto( /tmp/zm/zms-686810s.sock ) failed: No such file or directory]
and this appears when try to watch streaming images. Many times too:
Mar 13 08:15:55 zm zms[1021]: ERR [Unable to authenticate user]
Mar 13 08:15:55 zm zms[1022]: ERR [Unable to authenticate user]
Mar 13 08:15:55 zm zms[1023]: ERR [Unable to authenticate user]
Looks like a Msyql password error. I check for Users, Passwords in Mysql and .conf files for Zoneminder but everything is ok.
I downloaded zm4ms (ViseonViewer) and configure it to work with zoneminder server and surprise: it works!! then check for records. I can't see record streaming but can see images. I mean zoneminder and cameras are working but not for my web interface.
shutting down server I see an error message:
Stoping ZoneMinder: DBI connect('database=zm;host=localhost','user',...) failed: Can't connect to MySQL server through socket '/var/run/msyqld/mysqld.sock' (2) at /usr/local/share/perl/5.10.1/ZoneMinder/Logger.pm line 458 DBI connect('database=zm;host=localhost','user',...) failed: Can't connect to MySQL server through socket '/var/run/msyqld/mysqld.sock' (2) at /usr/local/share/perl/5.10.1/ZoneMinder/Database.pm line 90 Can't call method "trace" on an undefined value at /usr/local/share/perl/5.10.1/ZoneMinder/Database.pm line 92. Failure
Again I check for Users, Passwords in Mysql and .conf files for Zoneminder but everything is ok.
Starting server again the error message doesnt appear. Same situation with /etc/init.d/zm restart or start
Could somebody please help me. At this momento I dont know what else I can do
Thanks.
Thanks.
