320x240 resolution only with ZM and Foscam F18918W? ZM lock?
Posted: Thu Mar 15, 2012 7:15 pm
Hi all!
Beside the bug http://www.zoneminder.com/forums/viewto ... 5&start=15 I also have a resolution problem with ZM and the Foscam F18918W ipcam.
I cannot get it to work above the 320x240 resolution, in Zoneminder.
Via the webbrowser the 640x480 resolution works normally, when I login to the cam. But when I try to get the stream into a 640x240 mode into Zoneminder it fails.
Anybody experience the same issue or knows a workaround maybe? Are there config files locking the screen resolutions in Zoneminder?
I followed this wiki http://www.zoneminder.com/wiki/index.php/Foscam_FI8918W and this says that Zoneminder can handle the 640x480, but I doubt it after two days of google and playing with the settings.
Any help would be much appreciated!
