I recently setup zoneminder on a virtual machine on Centos 6.2 64bit . The install and compile of everything went off without issue and I am able to get the zoneminder web interface up and running. After setting up my 2 DCS-930L cameras I wasn't able to see any images or video streams. I have checked out post http://www.zoneminder.com/forums/viewto ... 29&t=18951 and that hasn't helped me any. As you can see from the logs zm is capturing data from the camera but when I try to play the active stream or review an event I get the error on the 3rd line.
Mar 23 11:23:56 zoneminder zmc_m1[20467]: INF [TVArea: 1000 - Capturing at 4.15 fps]
Mar 23 11:24:15 zoneminder zmc_m2[20475]: INF [Main: 2000 - Capturing at 10.31 fps]
Mar 23 11:24:44 zoneminder web_php[19879]: ERR [socket_sendto( /tmp/zm/zms-911408s.sock ) failed: No such file or directory]
Can't see images or video streams
Re: Can't see images or video streams
Could you run:
cd /tmp/zm/
ls -al /tmp/zm/
Basically to verify that the user the zoneminder process is running under has read/write access to that special file?
cd /tmp/zm/
ls -al /tmp/zm/
[root@zoneminder zm]# ls -al /tmp/zm/
total 8
drwxrwxr--. 2 apache apache 4096 Mar 23 11:24 .
drwxrwxrwt. 4 root root 4096 Mar 26 03:16 ..
srwxr-xr-x. 1 apache apache 0 Mar 23 11:13 zmdc.sock
total 8
