In my installation I can see in timeline only events of two hours before.
Zoneminder 1.25.0 and debian unstable.
I think this problem is related to timezone, mine is Europe/Rome.
Any Ideas?
Thanks.
Timeline show only events of two hours before [SOLVED]
Re: Timeline show only events of two hours before
I can't give you a real solution.
But why install it on unstable debian version ?
Is not really debian sid, but is crunchbang tracking sid.troublestarter wrote:I can't give you a real solution.
I use use my computer not only for videosurveillance but also for general purpose and the original version of evince that come with crunchbang ( stable version tracking squezee ) has a problem with antialias of scanned images, solved with the sid version.
The timeline problem is the same also with aptosid.
Re: Timeline show only events of two hours before [SOLVED]
Setting date.timezone in php.ini solved the problem.
