Zambozola timezone problem
fjenou
Post by fjenou »
Hi all,
I have a working Ubuntu 11.10 64bit with ZM 1.25.0, capturing and recording Foscam IP cameras with MJPEG.
My timezone is America/Sao_Paulo (GMT-3), php.ini date.timezone is set correctly the recorded events have the correct date/time, but Cambozola show all realtime and recovered event images with GMT.
Is there any tweaking I can do?
Thansk.
fjenou
Re: Zambozola timezone problem [Solved]
Post by fjenou »
After a lot of checking, I suddenly realized that the Linux server was using UTC as system time. As soon as I set the correct local timezone, the problem was solved...
