zmfilter.pl ' exited abnormally, exit status 9
teraquad
Post by teraquad »
Hi
I am having trouble getting my filters working. From examples posted here, I am pretty sure i have set them up properly. I do notice the error in the zmdc.log file. I was wondering if it rings a bell for someone who could help me out. I am running ver 1.24.4 and have 3 ip cams whitch all work well.
When i attempt to use a filter, ZM will collect the proper events and i can manually delete them. But there is no automatic action. I have to manualy arcive, delete, etc the target events. I am sure the filters are marked to run automaticly. Any way, I am at the end of my rope so to speak.
zmaudit.log
04/01/2012 16:32:22.426198 zmdc[2224].ERR ['zmfilter.pl ' exited abnormally, exit status 9]
04/01/2012 16:42:22.012542 zmdc[2224].INF [Starting pending process, zmfilter.pl]
04/01/2012 16:42:22.013912 zmdc[2224].INF ['zmfilter.pl' starting at 12/04/01 16:42:22, pid = 6784]
04/01/2012 16:42:27.476441 zmdc[2224].ERR ['zmfilter.pl ' exited abnormally, exit status 9]
04/01/2012 16:52:27.084348 zmdc[2224].INF [Starting pending process, zmfilter.pl]
04/01/2012 16:52:27.085709 zmdc[2224].INF ['zmfilter.pl' starting at 12/04/01 16:52:27, pid = 6892]
04/01/2012 16:52:32.548864 zmdc[2224].ERR ['zmfilter.pl ' exited abnormally, exit status 9]
04/01/2012 17:02:32.026053 zmdc[2224].INF [Starting pending process, zmfilter.pl]
04/01/2012 17:02:32.027468 zmdc[2224].INF ['zmfilter.pl' starting at 12/04/01 17:02:32, pid = 7232]
04/01/2012 17:02:37.519925 zmdc[2224].ERR ['zmfilter.pl ' exited abnormally, exit status 9]
04/01/2012 17:12:37.009537 zmdc[2224].INF [Starting pending process, zmfilter.pl]
04/01/2012 17:12:37.011056 zmdc[2224].INF ['zmfilter.pl' starting at 12/04/01 17:12:37, pid = 7328]
04/01/2012 17:12:42.588051 zmdc[2224].ERR ['zmfilter.pl ' exited abnormally, exit status 9]
04/01/2012 17:22:42.036414 zmdc[2224].INF [Starting pending process, zmfilter.pl]
04/01/2012 17:22:42.037906 zmdc[2224].INF ['zmfilter.pl' starting at 12/04/01 17:22:42, pid = 7487]
04/01/2012 17:22:47.720909 zmdc[2224].ERR ['zmfilter.pl ' exited abnormally, exit status 9]
04/01/2012 17:32:47.077189 zmdc[2224].INF [Starting pending process, zmfilter.pl]
04/01/2012 17:32:47.078424 zmdc[2224].INF ['zmfilter.pl' starting at 12/04/01 17:32:47, pid = 7582]
04/01/2012 17:32:52.550010 zmdc[2224].ERR ['zmfilter.pl ' exited abnormally, exit status 9]
zmfilter.log
04/01/2012 10:38:27.536480 zmfilter[2330].INF [Scanning for events]
04/01/2012 10:38:42.533474 zmfilter[2335].INF [Scanning for events]
04/01/2012 10:39:07.538903 zmfilter[2340].INF [Scanning for events]
04/01/2012 10:39:50.552256 zmfilter[2360].INF [Scanning for events using filter '_TempFilter1333291190']
04/01/2012 10:39:52.519624 zmfilter[2365].INF [Scanning for events]
04/01/2012 10:39:59.891824 zmfilter[2369].INF [Scanning for events using filter '_TempFilter1333291199']
04/01/2012 10:40:04.401665 zmfilter[2375].INF [Scanning for events using filter '_TempFilter1333291203']
04/01/2012 10:41:17.486582 zmfilter[2522].INF [Scanning for events]
04/01/2012 10:44:02.489147 zmfilter[2562].INF [Scanning for events]
04/01/2012 10:49:27.508991 zmfilter[2643].INF [Scanning for events]
04/01/2012 10:59:32.547320 zmfilter[2774].INF [Scanning for events]
04/01/2012 11:02:56.163631 zmfilter[2915].INF [Scanning for events using filter '_TempFilter1333292575']
04/01/2012 11:09:37.541330 zmfilter[2994].INF [Scanning for events]
04/01/2012 11:19:42.603145 zmfilter[3153].INF [Scanning for events]
04/01/2012 11:29:47.653849 zmfilter[3257].INF [Scanning for events]
04/01/2012 11:39:52.776409 zmfilter[3377].INF [Scanning for events]
Thanks!!
04/06/12
I have deleted and reinstalled zoneminder, Deleted and installed perl. Actually a number of times hoping to reset anything that could be causing my problem. But it has not worked. I am open to any input as i am having to delete everything by hand.
I would even be happy to hear that it is operator error!
Thanks again!
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
8)
m_kane
Re: zmfilter.pl ' exited abnormally, exit status 9
Post by m_kane »
I was facing that too. It started after I created filter that uploads events to my ftp server.
I noticed that even deleting "upload" filter did not help. But after I unticked "should zoneminder support uploading events from filters" in options, it started working again. Maybe I have something wrong in ftp settings, I haven't have time to investigate it yet.
teraquad
Post by teraquad »
Thanks for the reply.
I still haven't had any luck finding the problem. I am at the point that i am ready to reinstall fedora 16 and reinstall zoneminder Hoping that that will help. Thanks for the info about the filters, I think i will try and delete them before i take such a drastic step.
Thanks again!
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
8)
m_kane
Post by m_kane »
I also noticed that if I enable email sending in options, it also causes zmfilter to fail.
You can debug it running zmfilter.pl from command line. Just find binary first. It is in /usr/bin or /usr/local/bin.
For me it whines about perl zip componen, what guided me to investigate it. I changed UPLOAD_ARCH_FORMAT to "tar", and ftp started to work.
Note that enabling those will cause zmfilter to fail, regasrdless if any filter is using them or not.
m_kane
Post by m_kane »
by the way;
You maybe want also repair/optimize mysql tables. For me it caused strange behavior. Power failure or something had messed my tables. It luckily has happened only once.
Generally, I think zm is very robust software. It hasn't never crashed for me.
teraquad
Post by teraquad »
Thanks!
I will work on it tonight. That is good information.
Thanks!
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
8)
teraquad
Post by teraquad »
Well,
I am still working on the error. Not being familiar with SQL is my biggest problem right now, so i am looking into that with an eye toward cleaning up the database. I did have a power failure recently so that could well be my problem. I will post any progress here.
Thanks again for the info.
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
8)
teraquad
Post by teraquad »
:oops: Hi,
I have attempted to follow the advice given above with little results. There is much i dont follow. It has to be something simple that i am overlooking. I have reinstalled everything, sql, cameras, ffmpg, and the problem remains. Am i expecting the wrong thing?
I think that when setup properly, a filter should wake up at the preset interval and delete or archive or preform an action on the target events automaticly and then repeat indefinitely.
What i am seeing is that, When i leave it alone, nothing happens. If i submit or execute the filter then it selects the right events but does nothing further on it's own. I can delete the events by checking all the boxes and hitting delete. but i don't think that is how it supposed work.
I have attached my log files. Any help will be appriceated.
Thanks!
zmlogs.tar.gz
Log files.
(43.12 KiB) Downloaded 426 times
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
8)
robertclemens
Post by robertclemens »
A common exit error when you enable the upload function is that the perl module it is trying to load does not exist.
In this case it is Net::FTP.
Make sure you have that installed and that the path is picked up in perl.
perl -MNet::FTP -e "print \"Module installed.\\n\";"
If you see "Module installed." then you have it. If you see any other error then something is wrong with perl or that specific module.
Make sure your FTP settings tab is filled in correctly and has no weird characters. It is possible that your password contains some odd characters that are not being
interpreted correctly. If you use any funky characters, try changing it to something simple with letters and numbers and see if that helps.
If you are interested in throttling your upload speed you may want to read my post here:
http://www.zoneminder.com/forums/viewto ... =8&t=18984
teraquad
Post by teraquad »
Thanks!
Thanks for the reply, clear concise and to the point. I performed the test and received the module installed response. I turned FTP on and off with the same results as before. I am one step further along. Thank you very much for the reply. it was helpfull.
Thanks Again!
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
8)
robertclemens
I guess my next procedure would be to see what you enabled in that filter. Is it upload only or are you using other methods as well such as email?
Then we need to see what you are requiring from your system to make sure you have what you need. In your FTP options tab did you specify zip or tar?
If Zip
perl -MArchive::Zip -e "print \"Module installed.\\n\";"
If Tar
perl -MArchive::Tar -e "print \"Module installed.\\n\";"
If you enabled email
perl -MMIME::Lite -e "print \"Module installed.\\n\";"
perl -MNet::SMTP -e "print \"Module installed.\\n\";"
perl -MMIME::Entity -e "print \"Module installed.\\n\";"
Default requirements:
perl -MTime::HiRes -e "print \"Module installed.\\n\";"
perl -MDate::Manip -e "print \"Module installed.\\n\";"
perl -MGetopt::Long -e "print \"Module installed.\\n\";"
perl -MData::Dumper -e "print \"Module installed.\\n\";"
All of the above should be installed. If they are, make sure you have all your required settings filled in properly for zoneminder.
teraquad
Post by teraquad »
Thanks for the reply!
It is not my intention to E-mail or FTP any information, though it is possible i have inadvertently set something to do so. That being said the information you have requested is as follows.
[root@ZoneMinder ~]# perl -MArchive::Zip -e "print \"Module installed.\\n\";"
Module installed.
[root@ZoneMinder ~]# perl -MArchive::Tar -e "print \"Module installed.\\n\";"
Module installed.
[root@ZoneMinder ~]# perl -MMIME::Lite -e "print \"Module installed.\\n\";"
Module installed.
[root@ZoneMinder ~]# perl -MNet::SMTP -e "print \"Module installed.\\n\";"
Module installed.
[root@ZoneMinder ~]# perl -MMIME::Entity -e "print \"Module installed.\\n\";"
Module installed.
The event filter is set as
Date/Time less than now
sort by Date/Time Asc Limit to first 5
archive all matches
execute ^g
The ^g being the bell.
I have executed this filter in both submit and execute but it only returns the 5 items but preforms no action on them either automaticly or otherwise.
Thanks Again!
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
8)
teraquad
Post by teraquad »
Looks like i got ahead of myself!
[root@ZoneMinder ~]# perl -MTime::HiRes -e "print \"Module installed.\\n\";"
Module installed.
[root@ZoneMinder ~]# perl -MDate::Manip -e "print \"Module installed.\\n\";"
Module installed.
[root@ZoneMinder ~]# perl -MGetopt::Long -e "print \"Module installed.\\n\";"
Module installed.
[root@ZoneMinder ~]# perl -MData::Dumper -e "print \"Module installed.\\n\";"
Module installed.
Thanks!
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
8)
robertclemens
Okay so you are only trying to archive the events.
Most of my previous information was related to FTP/Email but it did have you check for a couple modules for Archival.
First things first. Is your zm.conf file correct? Located at /etc/zm/zm.conf
You will want to look for:
ZM_DB_HOST
ZM_DB_USER
ZM_DB_PASS
It almost sounds like you installed ZoneMinder but maybe did not get the MySQL part installed or completed. Did you install MySQL when you first installed ZoneMinder and did you create the base table schema from the provided SQL file?
So now you have the above variables in mind, are you running MySQL? I have mysqld running as you can see below. If you do not have a mysql process running then that is the start of your problem.
root@mythtv:/etc/zm# ps aux |grep mysql
mysql     1196  0.3  1.3 316808 54000 ?        Ssl  Apr02  61:00 /usr/sbin/mysqld
root     23824  0.0  0.0   7976   884 pts/0    S+   13:11   0:00 grep --color=auto mysql
If MySQL is running. We want to use the parameters listed at the top of this post to verify your connection.
Your ZM_DB_HOST is likely (or should be) localhost.
Your ZM_DB_USER is most likely zm
Your password should have been set by you.
So let's try a connection with that information. It *SHOULD* prompt for a password and that password *SHOULD* be what you have for your ZM_DB_PASS variable.
root@mythtv:/etc/zm# mysql -u zm -p
Enter password:
If you did not see the above or are unable to connect, then there is your problem.
If you do connect successfully, you could run a test query to make sure you have access to the database.
mysql> use zm;     (THIS WILL SELECT THE ZoneMinder DATABASE)
Reading table information for completion of table and column names
You can turn off this feature to get a quicker startup with -A
Database changed
Now lets do a couple read tests. This one will test reading the entire events table. If this does not work then you have an issue with permissions.
(THIS WILL LIST *EVERYTHING* IN THE EVENTS TABLE. YOU SHOULD SEE ***LOTS*** -- PROBABLY 2 ROWS PER EVERY EVENT)
mysql> select * from Events;
If the above command worked and listed all of your events, then you have read permission -- GOOD! Now see if your system has ever set an event as archived.
(THIS WILL LIST ALL ARCHIVED EVENTS TO SEE IF YOUR SYSTEM HAS EVER SET THE ARCHIVED FLAG TO ANY EVENT).
mysql> select * from Events where Archived=1;
If the above command worked then you need to test write permissions. Let's select a single event to play with. From your zoneminder website pick an event number and lets see what is set for it. In my case I chose event id 100.
Not sure how this will look when I post but under the Archived column (this is the number after the value 13 column) this event lists that value as 0 -- meaning it has not been archived.
mysql> select * from Events where Id=100;
| Id  | MonitorId | Name      | Cause  | StartTime           | EndTime             | Width | Height | Length | Frames | AlarmFrames | TotScore | AvgScore | MaxScore | Archived | Videoed | Uploaded | Emailed | Messaged | Executed | Notes       |
| 100 |         1 | Event-100 | Motion | 2012-03-16 15:40:37 | 2012-03-16 15:40:42 |   640 |    480 |   4.61 |     26 |           6 |       65 |       10 |       13 |        0 |       0 |        1 |       0 |        0 |        0 | Motion: All |
1 row in set (0.00 sec)
mysql>
So now let's set event id 100 as archived. I get a response back saying the row is changed -- meaning my write was successful!
mysql> update Events set Archived=1 where Id=100;
Query OK, 1 row affected (0.00 sec)
Rows matched: 1  Changed: 1  Warnings: 0
mysql>
We can look now and see the value for the Archived column is now 1 -- meaning that event has been archived (but not really in our case -- we are just testing the write permission)
The column is just after the 13 value. It is now 1.
| 100 |         1 | Event-100 | Motion | 2012-03-16 15:40:37 | 2012-03-16 15:40:42 |   640 |    480 |   4.61 |     26 |           6 |       65 |       10 |       13 |        1 |       0 |        1 |       0 |        0 |        0 | Motion: All |
mysql>
If the above write test worked, let us change that value back to 0 if that is were it was beforehand.
mysql> update Events set Archived=0 where Id=100;
mysql> quit;
Bye
If everything above worked, then something else is strangely wrong. I suspect at some point in the above you will have an issue -- that is where you will want to look.
1) Make sure MySQL is installed
2) Make sure MySQL is RUNNING.
3) Make sure you have created the zoneminder table with the default schema file.
4) Make sure you created a user and password in MySQL for zoneminder.
5) Make sure you can connect to MySQL using that login and password.
6) Make sure that login can read/write to the zoneminder table
7) Make sure the /etc/zm/zm.conf file correctly lists the MySQL information for your zoneminder account.
teraquad
Post by teraquad »
Please see the attached file!
Attachment not working.!
ZM_DB_HOST
ZM_DB_USER
ZM_DB_PASS
All found in /etc/zm.conf
[root@ZoneMinder ~]# ps aux |grep mysql
mysql 1301 0.1 2.0 310224 42496 ? Sl Apr13 6:09 /usr/libexec/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --log-error=/var/log/mysqld.log --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/lib/mysql/mysql.sock
root 26945 0.0 0.0 4592 788 pts/0 S+ 16:58 0:00 grep --color=auto mysql
[root@ZoneMinder etc]# mysql -u zmuser -p
Enter password:
Welcome to the MySQL monitor. Commands end with ; or \g.
Your MySQL connection id is 14572
Server version: 5.5.21 MySQL Community Server (GPL)
mysql> use zm
Database changed
mysql> use zm;
Database changed
mysql>
| 1383 | 3 | Event-1383 | Continuous | 2012-04-16 17:20:00 | 2012-04-16 17:30:00 | 352 | 288 | 599.96 | 9008 | 398 | 3421 | 8 | 21 | 0 | 0 | 0 | 0 | 0 | 0 | Motion: All |
| 1384 | 2 | New Event | Continuous | 2012-04-16 17:30:00 | NULL | 640 | 480 | 181.02 | 2100 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | |
| 1385 | 1 | New Event | Continuous | 2012-04-16 17:30:00 | NULL | 640 | 480 | 184.11 | 2000 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | |
| 1386 | 3 | New Event | Continuous | 2012-04-16 17:30:00 | NULL | 352 | 288 | 186.51 | 2800 | 67 | 399 | 5 | 9 | 0 | 0 | 0 | 0 | 0 | 0 | Motion: All |
1366 rows in set (0.01 sec)
mysql> select * from Events; (sample above)
Empty set (0.00 sec)
mysql>
mysql> select * from Events where Id=1370;
| 1370 | 1 | Event-1370 | Continuous | 2012-04-16 16:40:00 | 2012-04-16 16:50:00 | 640 | 480 | 600.06 | 6768 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | |
mysql>
mysql>
mysql> update Events set Archived=1 where Id=1370;
mysql>
1) Make sure MySQL is installed (** yes **)
2) Make sure MySQL is RUNNING. (** yes **)
3) Make sure you have created the zoneminder table with the default schema file. (** unsure **) Don't know what schema file is??
4) Make sure you created a user and password in MySQL for zoneminder. (** yes **)
5) Make sure you can connect to MySQL using that login and password. (** yes **)
6) Make sure that login can read/write to the zoneminder table (** yes **)
7) Make sure the /etc/zm/zm.conf file correctly lists the MySQL information for your zoneminder account. (** location ? **) The location is /etc/zm.conf
Thank you very much for your help here. It is obvious that i am completely in the dark but learning.
Thanks very much!
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
8)
