Apparently the progress bar and the control buttons aren't working at all.
For example when I preview a recorded event I can't do anything with the progress bar or the controls.
The video plays though.
Also the 'mode' 'rate' 'progress' 'zoom' attributes don't display anything.
In the timeline view I can move back and forth.
Similar situation is when i'm watching the live stream, there are controls under the video but whatever I do nothing happens.
The source video (tho i think not relevant as I do get the output from the cam) is a M7001 axis cam/decoder via ffmpeg source method.
Any help would be appreciated.
Progress bar and controls not working
- sshot of the event viewer/player
- zm.jpg (126.77 KiB) Viewed 1740 times
Re: Progress bar and controls not working
Solved.
PHP extensions such as gd and gettext weren't enabled on the server.
