Ubuntu 12.04 and ./configure error.
gallonin
Post by gallonin »
I have problem with ./configure:
ubuntu@ubuntu:~/ZoneMinder-1.25.0$ ./configure --with-webdir=/home/ZoneMinder-1.25.0
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
configure: WARNING: You can call configure with the --with-libarch option.
    This tells configure where to find architecture specific libraries.
    The default of 'lib' is usually ok but 64 bit machines may require lib64.
    e.g. --with-libarch=lib or --with-libarch=lib64
configure: WARNING: You can call configure with the --with-mysql option.
    This tells configure where to find the MySql C library and headers if configure cannot
    locate them automatically.
    e.g. --with-mysql=/usr/local or --with-mysql=/usr
configure: WARNING: You can call configure with the --with-ffmpeg option.
    This tells configure where to find the ffmpeg root directory within which are the libavcodec
    and libavformat files that can be used to build true MPEG streaming into ZoneMinder. Ensure that
    your copy of ffmpeg has installed libraries as well as binaries (use 'make installlib'). If you
    are using a local install of ffmpeg you may have to remove or rename a previous real installation
    as the headers and libraries from that will probably be picked up before your local copy.
    e.g. --with-ffmpeg=/usr/local
configure: WARNING: You can call configure with the --with-extralibs option.
    Ordinarily you will need to use this option only when your copy of ffmpeg has been built
    with support for additional formats and you would use this option to detail which additional
    libraries ffmpeg was built with so that it is able to link successfully with ZoneMinder.
    You will need to wrap this option in quotes if it contains any spaces.
    e.g. --with-extralibs="-lmp3lame"
configure: error: You must call configure with the --with-cgidir option.
    This tells configure where to install cgi files and scripts.
    e.g. --with-cgidir=/var/www/cgi-bin or --with-webdir=/www/vhtdocs/<site>/cgi-bin
What do I do badly?
