Page 1 of 1
ACTi ACD2100 Encoder Configuring With Zoneminder?
Posted: Fri Apr 13, 2012 5:50 pm
by prairietech
Has anyone successfully configured this encoder to work with ZM?
I have tried the ACTi monitor presets and neither work. Also tried just about every other monitor configuration I could think of with various rstp and ffmpg settings.
Re: ACTi ACD2100 Encoder Configuring With Zoneminder?
Posted: Mon Apr 16, 2012 10:58 am
by ddmitry
[quote="prairietech"]Has anyone successfully configured this encoder to work with ZM?
I am using this encoder
My settings:
Remote Protocol: HTTP
Remote Method: Simple
Remote Host Name: 192.168.1.101
Remote Host Port: 82
Remote Host Path : cgi-bin/system?USER=admin&PWD=XXXX&CHANNEL=1&GET_STREAM
Capture Width (pixels): 720
Capture Height (pixels): 576
Preserve Aspect Ratio
Orientation: Normal
CANNEL may be from 1 to 4
Posted: Tue Apr 17, 2012 1:01 am
by prairietech
Thank you for you reply! However I still have some questions. Can you tell me how your ACD2100 is configured regarding it's video settings? TCP? Multicast? Is port 82 your video streaming port is set to?
Would I be correct to assume the Remote Host Path would look like this?
cgi-bin/system?Admin&123456&CHANNEL=1&GET_STREAM
My user is Admin and defaulted password is 123456
Thank you again for your assistance.
ddmitry wrote:
My settings:
Orientation: Normal
