Is there any way to set modetect during certain time frames and turn it off for others? Even a simple cron job to twiddle the database would be OK. If the DB is touched to disable record on a camera what process needs to be told that the database has been changed?
Thank you,
Jerry Allen
MODETECT only during hours x-x?[Solved]
Debian 7.8 Zoneminder 1.28.1 from source AMD FX-8370 Processor 16 gig of ram. 11 HD IP cameras.
Re: MODETECT only during hours x-x? [solved]
