MODETECT only during hours x-x?[Solved]
Posted: Mon Apr 16, 2012 8:44 pm
Is there any way to set modetect during certain time frames and turn it off for others? Even a simple cron job to twiddle the database would be OK. If the DB is touched to disable record on a camera what process needs to be told that the database has been changed?
Thank you,
Jerry Allen
Thank you,
Jerry Allen
