ZM to House TV distribution help
Posted: Fri Apr 20, 2012 10:07 pm
Hi All
I am looking at including ZM into my (automated) house.
What I want to achieve is a channel for each camera on the TV. I also would like to get a montage of all cameras on the TV's.
A channel for each camera is fairly easy with one that has a composite output and a modulator (one for each), but I am not sure on the best way to deal with IP cameras and the montage.
The other option is to have one channel and then use the automation system to switch between the camera views.
There are four TV's in the house so it would be possible to use a cheap inexpensive device behind each TV (RasberryPi?) that could be used as a "client/viewer"
Whatever the result, it has to be easy for the handbrake (wife) to use and navigate.
Mick
Mick
