for a customer, i'm setting up a camera environment with ZoneMinder 1.25 (on Ubuntu 10.04.4 LTS 64)
(We have 5mbit dedicated upstream to our datacenter for max 10 camera's per location - ZoneMinder server is located in a DC)
The software is doing fine. (Motion detect runs well for 4 IP cams, at this moment, with to much BW, but I think I have to tweak some motion detect settings).
The only thing that is not working is a live view (So when clicking on the camera name, I should see the live stream of that specific camera?)
Here are some errors that could be the cause of not seeing the live view :
zmwatch 13764 ERR Can't open memory map file '/dev/shm/zm.mmap.4': No such file or directory zmwatch.pl
32755 ERR socket_sendto( /tmp/zm/zms-061661s.sock ) failed: No such file or directory includes/functions.php 2322
For the last error, I could not find anything like ffmpeg-libs or ffmpeg-libraries for my Ubuntu Server.15761 FAT You must have ffmpeg libraries installed to use remote camera protocol 'rtsp' for monitor 4 zm_monitor.cpp 2428
Any comments?
Thanks!
Regards,
Dieter
