Page 1 of 1
Problem downloading generated video
Posted: Tue May 08, 2012 5:03 pm
by piglet_74
I tried to search for this in the forums but couldn't refine the search enough to zero in on this issue. I just installed 1.24 on Ubuntu 11.10. I've had a number of ZM installs over the past few years. With this version, and I think I saw the same issue with 1.25, I could not download a video that I generated from an event. The file was usually 4kb in size and wouldn't play in VLC. After poking around with IE (I normally run google chrome) I noticed that the link to download the video was missing the events/ folder in the path. Everything else seems to work but downloading the video file. I edited the video.php file and added events/ to the line that creates the download link and it works fine now. Is this a bug or is this a miss-configuration on my part? like I said, I've installed this a number of times over the years and normally take default paths etc.
If this is an issue for other folks I can give more details about what I did to fix it.
Anyway, thanks for a great app. Rob.
