Blue flash frames since upgrade to 1.24.4
stealthboy
Post by stealthboy »
Ever since I upgraded my Fedora install from 14 to 15, and therefore at the same time upgraded to ZoneMinder 1.24.4, I've been getting hundreds of blue flash frames on all four of my Dlink cam feeds every day. This makes the system useless. I've seen some other threads on this issue with no solutions - anyone have any ideas on this? My camera setups did not change, and nothing changed with my internal network.
I would really appreciate any hints on solving this issue as it has pretty much made my whole zoneminder setup completely useless :(.
Thanks in advance!!
teraquad
Re: Blue flash frames since upgrade to 1.24.4
Post by teraquad »
I had this problem with the dlink 2ea 932l and 2ea 930l. Check that your firmware is up to date on the cameras. Then cut your cameras framerate to 5fps and it should clear up. Mine did. One 932L had rev1 firmware and it was very slow.
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
8)
