I configure zoneminder v.1.25 with ubuntu 12.04 desktop every thing is perfect and I view my all cam with zoneminder through local LAN. but I want view my all ip cam with zoneminder remotly out side the LAN. Is it possible if yes how we can do that? Thanks in advance I will wait for your response.
Atif
view zoneminder remotly outside lan
Re: view zoneminder remotly outside lan
First you need a dns provider (f.i. dyndns.com), and a router that supports dynamic dns service. Then you need to configure the account and router in order to open the port that enables the access from any computer on the web.
Dear boss,
without dyndns can we do that I mean simple port forward I did it but no success
Please help me step by step.
thanks in advance
Atif
thanks in advance
Atif
Well, try to open the same port that you use in apache in your router. Then find out which is your public ip and try to access from outside of your local lan (it will not work with your external ip in your internal lan).
