CentOS 5.8 Install problems.
cbjessup
Post by cbjessup »
I recently installed CentOS on a server and am trying to get ZoneMinder to install. I followed the steps on the CentOS part of the Wiki. I used the ./configure --with-webdir=/var/www/html/zm --with-cgidir=/var/www/cgi-bin --with-ffmpeg=/usr/local/share/ffmpeg CPPFLAGS="-D__STDC_CONSTANT_MACROS" option and when I try to make this is the output:
make  all-recursive
make[1]: Entering directory `/root/ZoneMinder-1.25.0'
Making all in src
make[2]: Entering directory `/root/ZoneMinder-1.25.0/src'
g++ -DHAVE_CONFIG_H -I. -I..  -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include   -g -O2 -MT zm_ffmpeg_camera.o -MD -MP -MF .deps/zm_ffmpeg_camera.Tpo -c -o zm_ffmpeg_camera.o zm_ffmpeg_camera.cpp
zm_ffmpeg_camera.cpp:105:44: error: missing binary operator before token "("
zm_ffmpeg_camera.h:39: error: ISO C++ forbids declaration of âAVFormatContextâ with no type
zm_ffmpeg_camera.h:39: error: expected â;â before â*â token
zm_ffmpeg_camera.h:41: error: ISO C++ forbids declaration of âAVCodecContextâ with no type
zm_ffmpeg_camera.h:41: error: expected â;â before â*â token
zm_ffmpeg_camera.h:42: error: ISO C++ forbids declaration of âAVCodecâ with no type
zm_ffmpeg_camera.h:42: error: expected â;â before â*â token
zm_ffmpeg_camera.h:44: error: ISO C++ forbids declaration of âAVFrameâ with no type
zm_ffmpeg_camera.h:44: error: expected â;â before â*â token
zm_ffmpeg_camera.h:45: error: ISO C++ forbids declaration of âAVFrameâ with no type
zm_ffmpeg_camera.h:45: error: expected â;â before â*â token
zm_ffmpeg_camera.cpp: In constructor âFfmpegCamera::FfmpegCamera(int, const std::string&, int, int, int, int, int, int, int, bool)â:
zm_ffmpeg_camera.cpp:35: error: âmFormatContextâ was not declared in this scope
zm_ffmpeg_camera.cpp:37: error: âmCodecContextâ was not declared in this scope
zm_ffmpeg_camera.cpp:38: error: âmCodecâ was not declared in this scope
zm_ffmpeg_camera.cpp:40: error: âmRawFrameâ was not declared in this scope
zm_ffmpeg_camera.cpp:41: error: âmFrameâ was not declared in this scope
zm_ffmpeg_camera.cpp: In destructor âvirtual FfmpegCamera::~FfmpegCamera()â:
zm_ffmpeg_camera.cpp:46: error: âmFrameâ was not declared in this scope
zm_ffmpeg_camera.cpp:46: error: âav_freepâ was not declared in this scope
zm_ffmpeg_camera.cpp:47: error: âmRawFrameâ was not declared in this scope
zm_ffmpeg_camera.cpp:51: error: âsws_freeContextâ was not declared in this scope
zm_ffmpeg_camera.cpp:54: error: âmCodecContextâ was not declared in this scope
zm_ffmpeg_camera.cpp:56: error: âavcodec_closeâ was not declared in this scope
zm_ffmpeg_camera.cpp:59: error: âmFormatContextâ was not declared in this scope
zm_ffmpeg_camera.cpp:61: error: âav_close_input_fileâ was not declared in this scope
zm_ffmpeg_camera.cpp: In member function âvoid FfmpegCamera::Initialise()â:
zm_ffmpeg_camera.cpp:78: error: âAV_LOG_DEBUGâ was not declared in this scope
zm_ffmpeg_camera.cpp:78: error: âav_log_set_levelâ was not declared in this scope
zm_ffmpeg_camera.cpp:80: error: âAV_LOG_QUIETâ was not declared in this scope
zm_ffmpeg_camera.cpp:80: error: âav_log_set_levelâ was not declared in this scope
zm_ffmpeg_camera.cpp:82: error: âav_register_allâ was not declared in this scope
zm_ffmpeg_camera.cpp: In member function âvirtual int FfmpegCamera::PrimeCapture()â:
zm_ffmpeg_camera.cpp:94: error: âmFormatContextâ was not declared in this scope
zm_ffmpeg_camera.cpp:94: error: âav_open_input_fileâ was not declared in this scope
zm_ffmpeg_camera.cpp:95: error: âerrnoâ was not declared in this scope
zm_ffmpeg_camera.cpp:98: error: âmFormatContextâ was not declared in this scope
zm_ffmpeg_camera.cpp:98: error: âav_find_stream_infoâ was not declared in this scope
zm_ffmpeg_camera.cpp:99: error: âerrnoâ was not declared in this scope
zm_ffmpeg_camera.cpp:103: error: âmFormatContextâ was not declared in this scope
zm_ffmpeg_camera.cpp:108: error: âCODEC_TYPE_VIDEOâ was not declared in this scope
zm_ffmpeg_camera.cpp:118: error: âmCodecContextâ was not declared in this scope
zm_ffmpeg_camera.cpp:118: error: âmFormatContextâ was not declared in this scope
zm_ffmpeg_camera.cpp:121: error: âmCodecâ was not declared in this scope
zm_ffmpeg_camera.cpp:121: error: âavcodec_find_decoderâ was not declared in this scope
zm_ffmpeg_camera.cpp:125: error: âmCodecâ was not declared in this scope
zm_ffmpeg_camera.cpp:125: error: âavcodec_openâ was not declared in this scope
zm_ffmpeg_camera.cpp:129: error: âmRawFrameâ was not declared in this scope
zm_ffmpeg_camera.cpp:129: error: âavcodec_alloc_frameâ was not declared in this scope
zm_ffmpeg_camera.cpp:132: error: âmFrameâ was not declared in this scope
zm_ffmpeg_camera.cpp:135: error: âPIX_FMT_RGB24â was not declared in this scope
zm_ffmpeg_camera.cpp:135: error: âavpicture_get_sizeâ was not declared in this scope
zm_ffmpeg_camera.cpp:138: error: âAVPictureâ was not declared in this scope
zm_ffmpeg_camera.cpp:138: error: expected primary-expression before â)â token
zm_ffmpeg_camera.cpp:138: error: âavpicture_fillâ was not declared in this scope
zm_ffmpeg_camera.cpp:141: error: âSWS_BICUBICâ was not declared in this scope
zm_ffmpeg_camera.cpp:141: error: âsws_getCachedContextâ was not declared in this scope
zm_ffmpeg_camera.cpp: In member function âvirtual int FfmpegCamera::Capture(Image&)â:
zm_ffmpeg_camera.cpp:159: error: âAVPacketâ was not declared in this scope
zm_ffmpeg_camera.cpp:159: error: expected `;' before âpacketâ
zm_ffmpeg_camera.cpp:163: error: âmFormatContextâ was not declared in this scope
zm_ffmpeg_camera.cpp:163: error: âpacketâ was not declared in this scope
zm_ffmpeg_camera.cpp:163: error: âav_read_frameâ was not declared in this scope
zm_ffmpeg_camera.cpp:172: error: âmCodecContextâ was not declared in this scope
zm_ffmpeg_camera.cpp:172: error: âmRawFrameâ was not declared in this scope
zm_ffmpeg_camera.cpp:172: error: âavcodec_decode_video2â was not declared in this scope
zm_ffmpeg_camera.cpp:182: error: âmRawFrameâ was not declared in this scope
zm_ffmpeg_camera.cpp:182: error: âmCodecContextâ was not declared in this scope
zm_ffmpeg_camera.cpp:182: error: âmFrameâ was not declared in this scope
zm_ffmpeg_camera.cpp:182: error: âsws_scaleâ was not declared in this scope
zm_ffmpeg_camera.cpp:188: error: âmCodecContextâ was not declared in this scope
zm_ffmpeg_camera.cpp:188: error: âmFrameâ was not declared in this scope
zm_ffmpeg_camera.cpp:193: error: âav_free_packetâ was not declared in this scope
make[2]: *** [zm_ffmpeg_camera.o] Error 1
make[2]: Leaving directory `/root/ZoneMinder-1.25.0/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/root/ZoneMinder-1.25.0'
make: *** [all] Error 2
I made sure ffmpeg was installed and working correctly..this is the output of ffmpeg:
ffmpeg version N-40947-gf452d6c Copyright (c) 2000-2012 the FFmpeg developers
  built on May 22 2012 10:41:08 with gcc 4.1.2 20080704 (Red Hat 4.1.2-52)
  configuration: --enable-gpl --enable-shared --enable-pthreads
  libavutil      51. 53.100 / 51. 53.100
  libavcodec     54. 22.100 / 54. 22.100
  libavformat    54.  6.100 / 54.  6.100
  libavdevice    53.  4.100 / 53.  4.100
  libavfilter     2. 75.100 /  2. 75.100
  libswscale      2.  1.100 /  2.  1.100
  libswresample   0. 15.100 /  0. 15.100
  libpostproc    52.  0.100 / 52.  0.100
Hyper fast Audio and Video encoder
usage: ffmpeg [options] [[infile options] -i infile]... {[outfile options] outfile}...
Use -h to get full help or, even better, run 'man ffmpeg'
I don't have a clue what I am doing wrong.
Chris
karathrace
Re: CentOS 5.8 Install problems.
Post by karathrace »
If it helps I am getting the same error with Centos 5.8 as well.
Ive read in other forums turning off ffmpeg may help but I haven't confirmed that personally.
If the CentOs Wiki has you retrieving the most recent version of ffmpeg (haven't read it myself), then that is the cause of the zonemidner compile problem. Try using an older version of ffmpeg. ffmpeg 0.65 works well for me using CentOS 6. ffmpeg 0.65 is in the rpmforge repositories so you don't have to compile it.
