Page 1 of 1
State of zoneminder doesn't change to running
Posted: Tue May 22, 2012 7:23 pm
by arcpo
Hi, I have installed ubuntu 10.04 and zoneminder 1.24.3.
Problem is that zoneminder start stopped and when i want change state to running, it doesn't change and continue stopped.
i'm sorry, i don't speak good english
Hola, tengo instalado en mi maquina ubuntu 10.04 y la version de Zoneminder 1.24.3
El problema es que ZoneMinder inicia "apagado", y cuando le quiero cambiar el estado, no cambia y se queda en apagado.
Si me pueden ayudar voy a estar agradecido.
Mi maquina es un i3, 8GB de RAM, 512GB HD.
Re: State of zoneminder doesn't change to running
Posted: Tue May 22, 2012 7:40 pm
by PacoLM
Post the output of /var/log/syslog when doing the state change.
Copia y pega lo que salga en el fichero /var/log/syslog, ayudara a entender lo que te pasa.
Saludos!
PacoLM
Posted: Wed May 23, 2012 1:19 pm
by malikinam
i have worked on ubuntu 10.04 and have installed it many times but i have some problem when i am going to work on it.
any body who can solve my problem please contact with me..
thanks..
Posted: Thu May 24, 2012 4:25 pm
by arcpo
when i try to change of state of zoneminder, out file in /var/log/syslog is:
Luego de intentar cambiar el estado de zoneminder, en /var/log/syslog sale esto:
zoneminder@ZM-Escritorio:~/Desktop$ cat /var/log/syslog
May 24 13:07:40 ZM-Escritorio rsyslogd: [origin software="rsyslogd" swVersion="4.2.0" x-pid="893" x-info="******************"] rsyslogd was HUPed, type 'lightweight'.
May 24 13:07:44 ZM-Escritorio anacron[1094]: Job `cron.daily' terminated
May 24 13:07:44 ZM-Escritorio anacron[1094]: Normal exit (1 job run)
May 24 13:08:18 ZM-Escritorio nullmailer[1125]: Rescanning queue.
May 24 13:08:18 ZM-Escritorio nullmailer[1125]: Starting delivery: protocol: smtp host: mail. file: 1337649232.18197
May 24 13:08:18 ZM-Escritorio nullmailer[2810]: smtp: Failed: Connect failed
May 24 13:08:18 ZM-Escritorio nullmailer[1125]: Sending failed: Host not found
May 24 13:08:18 ZM-Escritorio nullmailer[1125]: Starting delivery: protocol: smtp host: mail. file: 1337649235.18246
May 24 13:08:18 ZM-Escritorio nullmailer[2811]: smtp: Failed: Connect failed
May 24 13:08:18 ZM-Escritorio nullmailer[1125]: Starting delivery: protocol: smtp host: mail. file: 1337649235.18241
May 24 13:08:18 ZM-Escritorio nullmailer[2812]: smtp: Failed: Connect failed
May 24 13:08:18 ZM-Escritorio nullmailer[1125]: Delivery complete, 3 message(s) remain.
May 24 13:07:40 ZM-Escritorio rsyslogd: [origin software="rsyslogd" swVersion="4.2.0" x-pid="893" x-info="h t t p : / / w w w . r s y s l o g . c o m "] rsyslogd was HUPed, type 'lightweight'.
May 24 13:09:01 ZM-Escritorio CRON[2836]: (root) CMD ( [ -x /usr/lib/php5/maxlifetime ] && [ -d /var/lib/php5 ] && find /var/lib/php5/ -depth -mindepth 1 -maxdepth 1 -type f -cmin +$(/usr/lib/php5/maxlifetime) -delete)
May 24 13:09:17 ZM-Escritorio AptDaemon: INFO: Quiting due to inactivity
May 24 13:09:17 ZM-Escritorio AptDaemon: INFO: Shutdown was requested
May 24 13:09:18 ZM-Escritorio nullmailer[1125]: Rescanning queue.
May 24 13:09:18 ZM-Escritorio nullmailer[1125]: Starting delivery: protocol: smtp host: mail. file: 1337649232.18197
May 24 13:09:18 ZM-Escritorio nullmailer[2952]: smtp: Failed: Connect failed
May 24 13:09:18 ZM-Escritorio nullmailer[1125]: Sending failed: Host not found
May 24 13:09:18 ZM-Escritorio nullmailer[1125]: Starting delivery: protocol: smtp host: mail. file: 1337649235.18246
May 24 13:09:18 ZM-Escritorio nullmailer[2953]: smtp: Failed: Connect failed
May 24 13:09:18 ZM-Escritorio nullmailer[1125]: Starting delivery: protocol: smtp host: mail. file: 1337649235.18241
May 24 13:09:18 ZM-Escritorio nullmailer[2954]: smtp: Failed: Connect failed
May 24 13:09:18 ZM-Escritorio nullmailer[1125]: Delivery complete, 3 message(s) remain.
May 24 13:09:49 ZM-Escritorio zmpkg[3004]: INF [Command: start]
May 24 13:09:49 ZM-Escritorio zmpkg[3004]: ERR [Unable to run "/usr/local/bin/zmfix", output is ""]
May 24 13:10:01 ZM-Escritorio CRON[3018]: (root) CMD (if [ -x /etc/munin/plugins/apt_all ]; then /etc/munin/plugins/apt_all update 7200 12 >/dev/null; elif [ -x /etc/munin/plugins/apt ]; then /etc/munin/plugins/apt update 7200 12 >/dev/null; fi)
May 24 13:10:01 ZM-Escritorio CRON[3019]: (munin) CMD (if [ -x /usr/bin/munin-cron ]; then /usr/bin/munin-cron; fi)
May 24 13:10:18 ZM-Escritorio nullmailer[1125]: Rescanning queue.
May 24 13:10:18 ZM-Escritorio nullmailer[1125]: Starting delivery: protocol: smtp host: mail. file: 1337649232.18197
May 24 13:10:18 ZM-Escritorio nullmailer[3407]: smtp: Failed: Connect failed
May 24 13:10:18 ZM-Escritorio nullmailer[1125]: Sending failed: Host not found
May 24 13:10:18 ZM-Escritorio nullmailer[1125]: Starting delivery: protocol: smtp host: mail. file: 1337649235.18246
May 24 13:10:18 ZM-Escritorio nullmailer[3408]: smtp: Failed: Connect failed
May 24 13:10:18 ZM-Escritorio nullmailer[1125]: Starting delivery: protocol: smtp host: mail. file: 1337649235.18241
May 24 13:10:18 ZM-Escritorio nullmailer[3409]: smtp: Failed: Connect failed
May 24 13:10:18 ZM-Escritorio nullmailer[1125]: Delivery complete, 3 message(s) remain.
well, i hope can help... thanks
Bueno, no se si era eso lo que pedias... Espero puedan darme una mano
Posted: Thu May 24, 2012 10:15 pm
by PacoLM
Posted: Fri May 25, 2012 1:08 pm
by arcpo
ok, voy a echar un vistazo.
Posted: Tue Jun 05, 2012 4:34 pm
by arcpo
Hi, i could't solve my problem... so I started again with other Ubuntu, ubuntu 12.04 server... Now, my problem is that i can't see streaming of cameras, when i click on monitor only i can see a screen blue. I saw that the process 'zma' is not started.
PD: I use cameras IP, and i don't use video card.
Hola, no pude resolver el problema.... asi que empece de nuevo con otro ubuntu, ubuntu 12.04 server. Ahora mi problema es que no puedo ver lo que estan filmando las camaras cuando hago click en "monitor", solo veo una pantalla azul con el reloj del tiempo de la camara en la esquina superior izquierda. Lo que vi que no inicia el proceso zma.
Bueno, disculpen las molestias, espero puedan darme una mano
gracias
PD: Uso todas camaras IP, no uso tarjetas de video
Posted: Tue Jun 05, 2012 8:14 pm
by PacoLM
