zmtrigger.pl configuration
coinageboy
Post by coinageboy »
I am trying to use external trigger from Axis 211A to zmtrigger.pl runing Ubuntu server 64 12.04.
zmtrigger.pl is running but the Axis camera test to connect shows following error:
Connection failed:
502 Bad Gateway
The CGI was not CGI/1.1 compliant.
I tried to connect from another machine using telnet, port 6802 and it connects fine.
Also, zmtrigger.pl sometimes exits with following message:
variable is not a string at /usr/share/perl5/ZoneMinder/Memory/Mapped.pm line 109.
Any ideas??
Classic
Re: zmtrigger.pl configuration
Post by Classic »
You have to compile zm without mmap...thats work for me.
Lourenco
Post by Lourenco »
coinageboy wrote:Hi,
Connection failed:
502 Bad Gateway
Any ideas??
Did you solved you problem about ZM closing the connection via Telnet after some minutes connected?
coinageboy
Still observing the behaviour of this bug.
When I log into the port 6802, the telnet session dies after +/- 10 minutes. After a few retries, the system refuses to accept a new login...
Because of this problem my Zoneminder is missing major events - the TCP server probably crashes when the cameras and sensors start hitting. It restarts later, but the major event is lost..
I am polishing my Perl skills as I intend to figure it out.
If anybody tried to debug zmtrigger.pl, I am all ears to hear about it...
Augustine Lehecka
Lourenco
Post by Lourenco »
Classic wrote:You have to compile zm without mmap...thats work for me.
I'm not experienced in ZM or Linux. How can i do that?
In the instructions i followed to install zoneminder i have these steps involving mmap:
#Install Perl Modules#
perl -MCPAN -e shell
install CPAN
exit
install YAML PHP::Serialization Module::Load X10::ActiveHome
install Sys::Mmap
exit
It's needed to remove anything? Or just compile zoneminder without it?
AND
##Install Zoneminder#
cd /usr/src && wget http://www2.zoneminder.com/downloads/ZoneMinder-1.24.2.tar.gz
tar -xvzf ZoneMinder-1.24.2.tar.gz
cd /usr/src/ZoneMinder-1.24.2/src && nano zm_utils.cpp
#Insert the following line after other includes,then Ctrl-o to save, Ctrl-x to exit nano
#include <cstdio>
cd /usr/src/ZoneMinder-1.24.2 && \
./configure --with-webdir=/var/www/zm --with-cgidir=/usr/lib/cgi-bin \
ZM_DB_HOST=localhost ZM_DB_NAME=zm ZM_DB_USER=zmuser \
ZM_DB_PASS=zmpass ZM_SSL_LIB=openssl --enable-debug=no \
--with-webgroup=www-data --with-webuser=www-data --enable-mmap CPPFLAGS="-D__STDC_CONSTANT_MACROS ${CPPFLAGS}"
autoconf
aclocal
automake
make
mysql -u root -p < db/zm_create.sql
#Password that is requested is Mysql root password that was entered during install, not your ubuntu password.
mysql -u root -p
grant select,insert,update,delete on zm.* to 'zmuser'@localhost identified by 'zmpass';
quit
make install
I remove "--enable-mmap", right?
I have zoneminder already installed, so i can do this step again without any uninstallation?
Thank you.
Lourenco
Post by Lourenco »
Problem solved. Now zmtrigger works correctly with telnet input strings.
Just reinstalled Zoneminder without mmap.
It was just needed to change the command used to install ZM when appears "--enable-mmap" to "--enable-mmap=no".
Before re-installed ZM, I needed to drop the zm.sql database (via webmin). I did a backup and restore.
coinageboy
I am glad to see that someone figured this one out.
I still consider this problem a MAJOR BUG in Zoneminder.
sj3fk3
Post by sj3fk3 »
I totally agree.. This is a MAJOR BUG!
After a couple of triggers I get:
$ /usr/bin/zmtrigger.pl
variable is not a string at /usr/share/perl/5.14.2/ZoneMinder/Memory/Mapped.pm line 113.
For those who are using my zoneminder ppa, and update to libsys-mmap-perl is there which should fix the problem. All others should reference upstream
https://rt.cpan.org/Public/Bug/Display.html?id=91483
