Hi all,
Just 2 ideas:
I think it would be usefull the possibility to program the mode of the various sources. Example:
source1: from 8.00 to 20.00 Record, from 20.01 to 7.59 Modect
I would like to be able to change mode to all sources with one single click. Example
"all sources monitor", "all sources modect".
Bye,
Davide
programming modect/record
- zoneminder
- Site Admin
- Contact:
Re: programming modect/record
You can use 'run states' to help with this. If you click on 'Running' on the main console window you have the opportunity to save the current function of each monitor. You can name this. Then change all the monitors to have the other function you want and save that one with a different name. You can then select those states from that dialog to change the function of all monitors or use 'zmpkg.pl <state name>' to change it from a cron job.
Phil,
Phil,
